Script on WD NAS Zway stick
Coffeelover
Post by Coffeelover »
Hey,
How do I write/add scripts to zway for the wd Nas stick? I'd for example like to program a holistic heating schedule depending on presence, daytime, temperature and so on.
I'm willing to learn the coding language, but don't know where to start.
Raimund
Re: Script on WD NAS Zway stick
Z-Way uses JavaScript to do code. First of all select "Show system apps" in My Settings and you will immediatelly see many apps ready to go. If you need, you can write your own and store them in Z-Way using ssh access (WD provides it). Once done, you can even share your module (the module "store" is in beta testing, will be ready very soon)
