Device- and Elementassociation Bug
mcfanda
Post by mcfanda »
I'm using Device- and Elementassociation app to bind a z-wave sensor to a HTTP Device. When I set up the the association devices labels are fine, but the association does not work because the source device is wrong. In particular:
in the App set up I put:
Source: device A
Target: device B
I can see in the UI that:
device A is ZWayVDev_zway_7-0-48-1,
device B is "HTTP_Device_switchBinary_18
but when I look at the /opt/z-way-server/automation/storage/configxxxxxxx.json I found
"title":"KidsToOpenRule","params":{"sourceDevices":["ZWayVDev_zway_6-0-38"],"targetDevices":["HTTP_Device_switchBinary_18"]}
indeed, when I switch on the ZWayVDev_zway_6-0-38 device (which is a completely different device) the rule works.
I've tried to erase and replace the association rule, but each time the source device is picked at random!!!
please help
thanks, marcello
mcfanda
Re: Device- and Elementassociation Bug
Post by mcfanda »
I solved using "If -> Then" app, but the problem with "Device- and Elementassociation" app remains.
