including via Zwave.me
rtulp
Post by rtulp »
When I started with Zwave, I used Zwave.me to include devices.
After installing Domoticz, Domoticz imported all the devices from Zwave.me; but I can't find them in Zwave.me anymore. Now I've some difficulties with including some devices in Domoticz, so I'ld like to try it via Zwave.me. All my devices in Zwave.me are gone and including doesn't work anymore via Zwave.me.
How do I get Zwave.me working again?
michap
Re: including via Zwave.me
Post by michap »
If I understand right:
1) You have used at first Z-Way software with UZB stick / RaZberry
2) you have closed Z-Way software (stopped the service) and started Domoticz
(/etc/init.d/z-way-server stop and /etc/init.d/domoticz.sh start )
3) you have included in Domotivz the UZB stick / RaZberry smd imported the Z-Wave network
Now you are going back:
4) You have closed the Domoticz application ( /etc/init.d/domoticz.sh stop )
5) you have started the Z-Way service (/etc/init.d/z-way-server start)
Now you do not see the devices in Z-Way?
Please confirm that you all this have done - and what you are using (UZB stick / RaZberry, Windows or Raspberry,...)
And - please add the log from the moment after starting Z-Way software.
Log you can find here: /var/log/z-way-server.log
I think it could be possible that domoticz was still running and the UZB-stick/RaZberry was used already)
Michael
rtulp
Post by rtulp »
Hi Michael,
Thanks, that solves the problem, Domoticz was still running, problem solved, except that the Fibaro is still not included.. :-(
