Hi, I added a new garage door sensor on my network and everything configured correctly. but I am having few issues over the last few days after the setup.
1. The communication between my razberry and sensor was flaky, and i am not sure if this is due to distance between the device and the battery powered sensor, I moved my raspberry pi a little close yesterday and for now it seem to do better.
2. My sensor has always been showing up as 'On' on UI for some reason, even if I open the door and close it, the value on UI does not change, nothing gets shown for the sensor in the UI log, the associated button device does show up in log though.
Any ideas what should I try. I am on v2.2 version of z-way.
Garage door sensor always on
golaonline
Re: Garage door sensor always on
Well.. I re-inserted the battery in my sensor and i see a notification on UI that device came back to life, and its been doing ok so far in last few hours of my testing. Are there any known issues with v2.2.0 or any device/ software behavior inconsistency issues that i should know. I am planning to adding more devices on my network and would like to make right decisions.
