Both - off
[2016-03-08 20:56:23.557] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2016-03-08 20:56:25.962] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2016-03-08 20:56:28.994] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
Swith 1 - off
[2016-03-08 20:58:16.322] [D] [zway] SETDATA devices.10.instances.1.commandClasses.37.data.level = False
[2016-03-08 20:58:16.514] [D] [zway] SETDATA devices.10.instances.1.commandClasses.37.data.level = False
[2016-03-08 20:58:16.534] [D] [zway] SETDATA devices.10.instances.1.commandClasses.37.data.level = False
[2016-03-08 20:58:18.182] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
Swith 2 - off
[2016-03-08 20:59:37.834] [D] [zway] SETDATA devices.10.instances.2.commandClasses.37.data.level = False
[2016-03-08 20:59:37.978] [D] [zway] SETDATA devices.10.instances.2.commandClasses.37.data.level = False
[2016-03-08 20:59:38.161] [D] [zway] SETDATA devices.10.instances.2.commandClasses.37.data.level = False
[2016-03-08 20:59:40.346] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
but when I press the actual switch it shows
Switch 1 - on
[2016-03-08 21:02:40.234] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
Switch 2 - on
[2016-03-08 21:03:12.018] [D] [zway] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
How come it's always instances.0 when i press the switch, instead of the actual instance - as when I press the button in the GUI? Anyone that has configured Qubino successfully? Have to say that it really doesn't help that the association stuff in the expert ui is totally messed up
