Hi all!
I am having a problem with the Everspring AN157-2 on\off module.
It was included in the z-wave network with no problems but it turns off and on every two seconds with the relay click without any reason. I do not understand why this happens. The other one works fine.
Here is the video showing the problem: https://www.youtube.com/watch?v=OtSEDguq8ac
any idea why this happens?
Everspring on\off module problem
- DomotikQuebec
- Contact:
Re: Everspring on\off module problem
I would first contact Everspring.
If they can't help, I would contact Vera.
Mario Gravel
Domotik Quebec
Domotik Quebec
Thanks for the help. I tried to contact Everspring with no luck.DomotikQuebec wrote:I would first contact Everspring.
I will try to contact Vera though but I have a feeling that they are not the problem here
I am having the same issue on several units.
I don´t think it is related to the Vera3 I have and MIcasaverde is the WORST company when it comes to support... Just look at their website, it is down for days and they cannot fix it...
Anyway. I tried changing the 3 capacitors as well as the relay in one module. Unfortunately, this did not change anything at all.
At least now I know those components are all fine. I bought this module in 2012. It started failing around 2015.
I just contacted Everspring with the technical details.
My Vera is currently busy but I will trying deassociating the module and associating it again.
and the de-inclusion re-inclusion did not help either.
Here is my video: https://www.youtube.com/watch?v=IU3bS7ATMjU
At the beginning, the device is off.
I turn it ON from the Vera controller.
I let it do its craziness then turn it off at the end from the controller again.
Since I have a second controller (other type, other brand), I will probably test from there.
I also tested with my controller OFF and the issue remains so I doubt this is related to the controller.
Hi all
Still have the problem with those Everspring modules.
Seems like the only solution is never buy anything from Everspring
