Hi!
It seems that there is a Problem with the Z-Way Z-Wave stack or the Fibaro Wall Plug (FGWPF-101). I've got version 2.2.2 installed and I tried to reset and re-include this device, but the interview step never gets finished. I waited for about 12h to complete, but the system stick at this state: (Screenshot) https://www.dropbox.com/s/64j2370ri7jmt ... 5.png?dl=0
The inclusion was between a third node, so no direct communication between razberry and the plug was possible.
All the other nodes (~10) are working fine.
Do you have any advice?
BR
Sebastian
Fibaro Wall Plug - Interview never completes.
Re: Fibaro Wall Plug - Interview never completes.
Ah, forget to mention:
If I move the plug next to the raspberry, the interview is finished very fast. And then the device is dead. Here a screenshot of the job queue, after I switched to the Configuration tab in expert UI and pressed "Update from device" because all values were red (out of sync): https://www.dropbox.com/s/g5pd2k5ue4f3t ... 1.png?dl=0
Is this device just crap?
One more screenshot with from the Interview tab with version numbers: https://www.dropbox.com/s/6jfqz7xgo11qm ... 9.png?dl=0
