Hi
I got Fibaro Motion sensor and it seems the behavior is different regarding the version.
On log, i got this trame with ON-OFF for Fibaro version 2.7
[2016-05-03 21:49:26.631] [D] [zway] RECEIVED: ( 01 0D 00 04 00 14 07 56 01 30 03 FF D1 CB 64 )
[2016-05-03 21:49:26.632] [D] [zway] SENT ACK
[2016-05-03 21:49:26.633] [D] [zway] SETDATA devices.20.data.lastReceived = 0 (0x00000000)
[2016-05-03 21:49:26.635] [D] [zway] SETDATA devices.20.instances.0.commandClasses.48.data.1.level = True
[2016-05-03 21:49:26.636] [D] [zway] SETDATA devices.20.instances.0.commandClasses.48.data.1 = Empty
[2016-05-03 21:49:26.650] [D] [zway] RECEIVED: ( 01 0D 00 04 00 14 07 60 0D 01 01 20 01 FF 56 )
[2016-05-03 21:49:26.653] [D] [zway] SENT ACK
[2016-05-03 21:49:26.654] [D] [zway] SETDATA devices.20.data.lastReceived = 0 (0x00000000)
[2016-05-03 21:49:26.669] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcNodeId = 20 (0x00000014)
[2016-05-03 21:49:26.670] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcInstanceId = 1 (0x00000001)
[2016-05-03 21:49:26.671] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.level = 255 (0x000000ff)
[2016-05-03 21:49:26.748] [core] Notification: device-info (device-OnOff): {"dev":"Salon General purpose (20.0.48.1)","l":"on"}
[2016-05-03 21:49:27.029] [core] Notification: device-info (device-OnOff): {"dev":"Salon (20.1.1) Button","l":"on »}
On 3.2, i don't have the ON-OFF event:
[2016-05-03 21:48:15.493] [D] [zway] RECEIVED: ( 01 08 00 04 00 16 02 98 40 3F )
[2016-05-03 21:48:15.494] [D] [zway] SENT ACK
[2016-05-03 21:48:15.495] [D] [zway] SETDATA devices.22.data.lastReceived = 0 (0x00000000)
[2016-05-03 21:48:15.497] [zway] Node 22:0 CC Security: sending Nonce Report
[2016-05-03 21:48:15.498] [zway] Adding job: Nonce Report
[2016-05-03 21:48:15.499] [D] [zway] SENDING (cb 0x45): ( 01 11 00 13 16 0A 98 80 BB BC 62 F1 16 57 B5 D7 05 45 0E )
[2016-05-03 21:48:15.503] [D] [zway] RECEIVED ACK
[2016-05-03 21:48:15.507] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-05-03 21:48:15.508] [D] [zway] SENT ACK
[2016-05-03 21:48:15.509] [D] [zway] Delivered to Z-Wave stack
[2016-05-03 21:48:15.523] [D] [zway] RECEIVED: ( 01 07 00 13 45 00 00 02 AC )
[2016-05-03 21:48:15.524] [D] [zway] SENT ACK
[2016-05-03 21:48:15.525] [zway] Job 0x13 (Nonce Report): Delivered
[2016-05-03 21:48:15.526] [D] [zway] SETDATA devices.22.data.lastPacketInfo.delivered = True
[2016-05-03 21:48:15.527] [D] [zway] SETDATA devices.22.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-05-03 21:48:15.528] [D] [zway] SETDATA devices.22.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-05-03 21:48:15.529] [D] [zway] SETDATA devices.22.data.lastPacketInfo = **********
[2016-05-03 21:48:15.529] [D] [zway] SendData Response with callback 0x45 received: received by recipient
[2016-05-03 21:48:15.530] [D] [zway] SETDATA devices.22.data.lastSend = 323069 (0x0004edfd)
[2016-05-03 21:48:15.531] [D] [zway] Job 0x13 (Nonce Report): success
[2016-05-03 21:48:15.539] [zway] Removing job: Nonce Report
[2016-05-03 21:48:15.542] [D] [zway] RECEIVED: ( 01 23 00 04 00 16 1D 98 81 E8 B1 AB 66 05 52 94 B2 4C BA 28 99 C3 73 2B B4 68 C3 BB 61 85 E7 66 BD 16 89 EE FE )
[2016-05-03 21:48:15.543] [D] [zway] SENT ACK
[2016-05-03 21:48:15.544] [D] [zway] SETDATA devices.22.data.lastReceived = 0 (0x00000000)
[2016-05-03 21:48:15.552] [zway] Node 22:0 CC Security: Received a secure message
[2016-05-03 21:48:15.553] [D] [zway] SETDATA devices.22.instances.0.commandClasses.152.data.firstPart = **********
[2016-05-03 21:48:15.554] [zway] Node 22:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 08 00 ]
[2016-05-03 21:48:15.555] [D] [zway] SETDATA devices.22.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2016-05-03 21:48:15.556] [D] [zway] ( zero-length buffer )
[2016-05-03 21:48:15.557] [D] [zway] SETDATA devices.22.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2016-05-03 21:48:15.560] [D] [zway] SETDATA devices.22.instances.0.commandClasses.113.data.7.eventString = "Motion detected, location unknown"
[2016-05-03 21:48:15.561] [D] [zway] SETDATA devices.22.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2016-05-03 21:48:15.562] [D] [zway] SETDATA devices.22.instances.0.commandClasses.113.data.7 = Empty
How to have On OFF event on v3.2 ?
Any clue is welcome.
thanks in advance
regards
FIBARO Motion Sensor version 2.7 and 3.2 diff
Re: FIBARO Motion Sensor version 2.7 and 3.2 diff
core] Notification: XXXXX <=== this trame is missing
ok issue was about group association.
on v2.7 association are automated.
on v3.2, you have to go to expert, select your sensor; then go to association and add a new one related to "Motion".
that's it.
that's it.
