try to combine 1 Secure SRT321 and >=2 Danfoss LC13 together with razberry and z-way (v2.2.2) in order to use the srt321 as a kind of remote control for the at lest 2 Danfoss living connects beside the web gui of z-way. The aim is to use both the z-way web GUI and the srt321 alternatively to adjust the temperature setpoint on the lc13's.
I've seen and tried to play around (with 1 lc13 only) with the solution in https://forum.z-wave.me/viewtopic.php?f=3423&t=20718.
But no success, creating an app via "Load custom JavaScript" ends in: "Something went wrong".
Can somebody help with a working solution?
combine srt321 and lc13
Re: combine srt321 and lc13
coming back on this issue, hoping, anybody can help:
Did now try to bind Danfoss LC13's to the SRT321 via api (following hints in https://forum.z-wave.me/viewtopic.php?f=3423&t=20718):
http://IP:8083/JS/Run/zway.devices[33]. ... oint.Set(1, this.value);});
where device[33] is the SRT while device[10] and [11] are the LC13's.
Did work for a while, but somehow broke.
Changing the Temperature at SRT results in an Event: "Error during perform command execution: Error: Invalid argument".
Does anybody have an idea? Has anybody such a combination up and running and if, then how?
Would be even better, to have this kind of "Master-Slave-Thermostat" as an app. Can anybody help with this?
Any hint is appreciated...
I would also like to control the SetPoint of the LC13 with the buttons of my room temperature sensor. But Currently I am trying to setup just 1:1 binding.
I am not a JavaScript guru but have you tried to use multiple function() in a single bind? Something like this:
http://IP:8083/JS/Run/zway.devices[33]. ... alue);} );
May be some ";" is mising there but I guess it could be valid javascript. Or may be encapsulating both functions in another function like:
http://IP:8083/JS/Run/zway.devices[33]. ... lue);}} );
But I am only guessing
Regards
Regards
Just for the records: Meanwhile I discovered the Association app, which does the magic...
Hi!
Know this is an old thread, but could you possibly give more details on how you got the Danfoss Thermostats setup?
I have a Danfoss living connect thermostat, which I can connect to, do interview, see link status - but association does not work, so I cant use it...
I get the following message in UI Expert:
"Can not configure associations: groups were not reported by the device. Do interview."
I have done interview, and got reply from the thermostat, but it doesnt help me much...
Best regards,
Mogens
Best regards,
Mogens
