Razberry as secondary controller?
alan
Post by alan »
I've included the Razberry as a secondary controller in the network and would like to make it a backup controller in case the primary breaks.
Because of that, after the inclusion I hoped to assign it SUC and SIS capabilities from the primary controllers UI.
However it failed, reporting "SUC set failed" in the controller queue.
Also, the interviewing process s never successfully completed, always stopping on the MultiChannel command class:
/: None (16:15)
supported: true (16:15)
version: 4 (16:15)
security: false (16:15)
interviewDone: false (16:15)
interviewCounter: 9 (16:15)
endPoints: 0 (16:15)
aggregated: 0 (16:15)
dynamic: None (16:15)
identical: None (16:15)
Was anybody successful in setting this?
Re: Razberry as secondary controller?
Only your Primary controller is able to assign your RaZberry SUC or SIS role. RaZberry (being secondary) can not do it.
To analyze MultiChannel problem log is required.
