Error uploading image to rooms
jstaffon
Post by jstaffon »
I was able to upload images for my Rooms in versions previous to v2.2.2. Now after upgrading to v2.2.2, I receive this error when uploading images:
SmartHome UI - ERROR
Unable to upload file.
I've checked and the image size is the recommended 200x200, less than 600KB and in a jpeg format. Any suggestions?
holger
Re: Error uploading image to rooms
Post by holger »
I can confirm this issue. I created gifs and was able to upload them.
jstaffon
Post by jstaffon »
That's good news.....I think. I'll change mine to gifs until it's resolved. Btw, what version are you running? Are you aware of their "v2.2.2-test-webserver.." build?
Note that this test build had problems with uploads. There is a new one made today that should fix general upload problem. May be your particular problem too
lademeister
Post by lademeister »
Doesn't work for me as well.
200x200 as jpg and gif and below 600kb with 2.2.2-new-webserver doesnt accept any image uploads, no matter what I try,
where are the images stored on the raspberry and how do they have to be named? I would then just upload a file manually to the corresponding folder of the room.
