Hej all,
since I've updated to 2.2.2 I have several problems with the Web-UI:
* I cannot upload any images for rooms
* I cannot select a device description for any of my devices (unable to load data)
* Expert View > Network > Timing Info sometimes does not work (Unable to handle data from server)
I've seen that at least one issue is already known and adressed properly:
https://github.com/Z-Wave-Me/z-way-issues/issues/107
Can anybody confirm that the release v2.2.2-test-new-webserver-8-ga9cd319 solved those issues?
Besides that I really like version 2.2.2
Thanks in advance
Dennis
Issue since 2.2.2
Re: Issue since 2.2.2
Nobody has any experience?
Is there a time estimate when 2.2.3 is going to be released?
Is it possible to put images manually to the server without uploading them via the web ui?
Is there any other way to set the device description? For now I cannot set any properties on some wallplugs and motion sensors
I have also the problem with the images. The problem with the device descripton is solved in some 2.2.2 special version.
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
Fibaro Multi Sensor
