Major problem, I'm unable to login and get a server error.
Worse still is that previously I could log into WEBIF, however all I get now is:
Webif is switched off. You can switch it on from Z-Way UI or box shell
I can't get into the UI, how can I access the box shell?
Unable to login to WEBIF
Re: Unable to login to WEBIF
You can enable it via shell. Here is the command: viewtopic.php?f=3422&t=22911&start=20#p61622
