Webcam Camera PTZ control device not working
_Thomas_
Post by _Thomas_ »
I have defined a camera as device from the generic Webcam template. The camera is a IPC-100 AC by the way, it is a cheap camera from Medion available here in Germany. I have found the HTTP API commands and I can see the video stream incoming in the z-wave UI. However I can not control the PTZ position of the camera. I have added the correct URLs (I checked these manually). But the Z-Wave is logging me following error: ReferenceError: http is not defined
2016-07-11 12:31:49.258] [I] [core] Notification: error (module): Error during perform command execution: ReferenceError: http is not defined
[2016-07-11 12:31:49.268] [I] [core] ReferenceError: http is not defined
    at vDev.controller.devices.create.handler (automation/modules/Camera/index.js:102:21)
    at _.extend.performCommand (automation/classes/VirtualDevice.js:289:37)
    at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:328:60)
    at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:2387:52)
    at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:258:41)
    at automation/WebserverRequestRouter.js:32:35
    at WebServer.document_root (automation/Webserver.js:29:11)
Additionally the Webcam module states: The URL provided is not a valid web address. But in fact it is and it is working also in the view: http://192.168.188.42/videostream.cgi?user=admin
Do you have any idea?
Re: Webcam Camera PTZ control device not working
What Z-Way version are you using? OS?
Looks http module is not loaded in Z-Way....
