Problem compilation
pepemarchena
Problem compilation
Post by pepemarchena »
someone has encountered this problem?
open preproc\ctags_target_for_gcc_minus_e.cpp: The system can not find the file specified..
Error compiling for board Z-Wave>ME Z-Uno.
thank you very much.
Re: Problem compilation
Please add more log output
pepemarchena
Hi, thanks for your response.
Arduino: 1.6.9 (Windows 7), Board: "Z-Wave>ME Z-Uno, Europe, Enabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Tomas\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Tomas\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Tomas\Documents\Arduino\libraries" -fqbn=Z-Uno:zw8051:zuno:Frequency=Eu,Security=On -ide-version=10609 -build-path "C:\Users\Tomas\AppData\Local\Temp\build72159669c382c754979add19c3b5dc37.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Tomas\Documents\Arduino\sketch_aug14a\sketch_aug14a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Tomas\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Tomas\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Tomas\Documents\Arduino\libraries" -fqbn=Z-Uno:zw8051:zuno:Frequency=Eu,Security=On -ide-version=10609 -build-path "C:\Users\Tomas\AppData\Local\Temp\build72159669c382c754979add19c3b5dc37.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Tomas\Documents\Arduino\sketch_aug14a\sketch_aug14a.ino"
C:\Users\Tomas\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/compiler build "C:\Users\Tomas\AppData\Local\Temp\build72159669c382c754979add19c3b5dc37.tmp/sketch_aug14a.ino" -r C:\Users\Tomas\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.7 -p C:\Users\Tomas\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/ -o '-mmcs51 --out-fmt-ihx --model-large --verbose --debug --use-stdout --code-loc 0x8000 --xram-loc 0x3000'
open C:\Users\Tomas\AppData\Local\Temp\build72159669c382c754979add19c3b5dc37.tmp\preproc\ctags_target_for_gcc_minus_e.cpp: El sistema no puede encontrar el archivo especificado.
pepemarchena
Solved. The problem was the version of the arduino environment.
With the 1.6.5 works perfectly.
Thank you all.
jan_vanzeggelaar
Post by jan_vanzeggelaar »
I know this is an old thread, but I ran into the same problem recently whenI wanted to change something in my existing Z-Uno code.
Has this been solved for newer versions of the IDE or doe I really need to keep using an old IDE only for the Z-Uno?
Jan
New IDE can be used. Or even better use VSCode. Please don't rely on posts back from 2016
DoinitSideways
Post by DoinitSideways »
Ive just done a fresh install...
Arduino IDE 2.3.4
Z-Uno Boards 2.1.8
Have succesfully run the bootloader, but i cannot get the Blink example to compile or upload as per the installation guide...
I get this...
[9268] Failed to execute script compiler
Traceback (most recent call last):
File "compiler.py", line 2090, in <module>
File "compiler.py", line 2084, in Main
File "compiler.py", line 1808, in preard_func
File "shutil.py", line 130, in copy2
File "shutil.py", line 83, in copyfile
IOError: [Errno 2] No such file or directory: 'C:\\Users\\doini\\AppData\\Local\\arduino\\sketches\\DE8942D2FDF7BC8F70CFAABF7C07B84E\\preproc\\ctags_target_for_gcc_minus_e.cpp'
exit status 0xffffffff
Compilation error: exit status 0xffffffff
