is it possible, that the function "delayMicroseconds" is not implemented? It is mentioned on the reference-page but i get comiler errors, when i try to use it.
Errors:
Arduino: 1.6.5 (Windows 7), Platine: "Z-Wave>ME Z-Uno, Europe, Disabled"
C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/compiler build C:\Users\xx\AppData\Local\Temp\build3273354828723812551.tmp/KY-015.cpp -r C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.7 -p C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/ -o -mmcs51 --out-fmt-ihx --model-large --verbose --debug --use-stdout --code-loc 0x8000 --xram-loc 0x3000
ab64e9d048c79431b4af475b0225eeea.c:36: warning 88: cast of LITERAL value to 'generic' pointer
from type 'const-char literal'
to type 'const-char generic* fixed'
ab64e9d048c79431b4af475b0225eeea.c:40: warning 88: cast of LITERAL value to 'generic' pointer
ab64e9d048c79431b4af475b0225eeea.c:74: warning 112: function 'delayMicroseconds' implicit declaration
KY-015.ino:55:1:error: too many parameters
ab64e9d048c79431b4af475b0225eeea.c:90: warning 88: cast of LITERAL value to 'generic' pointer
too many parametersPhilipp
