razberry 2.2.3. I need to update the device parameters 51/52/53 because i had an dimmer bypass for
the LEDs. The problem is that after i set the parameter to 20 for example the UI shows 3 after i pressed
the "save this parameter" button which is the minimum value for that parameter. The behaviour is excatly the same
for all 3 parameters. Everytime i update the Parameter it is set to the minimum. Any ideas?
/var/log/z-way-server.log
[2016-09-07 07:39:15.039] [I] [zway] Adding job: Configuration Set
[2016-09-07 07:39:15.047] [I] [zway] Adding job: Configuration Get
[2016-09-07 07:39:15.049] [D] [zway] SENDING (cb 0x18): ( 01 0C 00 13 0B 05 70 04 35 01 0A 25 18 99 )
[2016-09-07 07:39:15.056] [D] [zway] RECEIVED ACK
[2016-09-07 07:39:15.058] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-09-07 07:39:15.059] [D] [zway] SENT ACK
[2016-09-07 07:39:15.061] [D] [zway] Delivered to Z-Wave stack
[2016-09-07 07:39:15.124] [D] [zway] RECEIVED: ( 01 07 00 13 18 00 00 07 F4 )
[2016-09-07 07:39:15.125] [D] [zway] SENT ACK
[2016-09-07 07:39:15.125] [I] [zway] Job 0x13 (Configuration Set): Delivered
[2016-09-07 07:39:15.125] [D] [zway] SETDATA devices.11.data.lastPacketInfo.delivered = True
[2016-09-07 07:39:15.126] [D] [zway] SETDATA devices.11.data.lastPacketInfo.packetLength = 8 (0x00000008)
[2016-09-07 07:39:15.126] [D] [zway] SETDATA devices.11.data.lastPacketInfo.deliveryTime = 63 (0x0000003f)
[2016-09-07 07:39:15.129] [D] [zway] SETDATA devices.11.data.lastPacketInfo = **********
[2016-09-07 07:39:15.131] [D] [zway] SendData Response with callback 0x18 received: received by recipient
[2016-09-07 07:39:15.137] [D] [zway] SETDATA devices.11.data.lastSend = 357928 (0x00057628)
[2016-09-07 07:39:15.138] [D] [zway] Job 0x13 (Configuration Set): success
[2016-09-07 07:39:15.139] [I] [zway] Removing job: Configuration Set
[2016-09-07 07:39:15.203] [D] [zway] SENDING (cb 0x19): ( 01 0A 00 13 0B 03 70 05 35 25 19 92 )
[2016-09-07 07:39:15.205] [D] [zway] RECEIVED ACK
[2016-09-07 07:39:15.209] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-09-07 07:39:15.210] [D] [zway] SENT ACK
[2016-09-07 07:39:15.210] [D] [zway] Delivered to Z-Wave stack
[2016-09-07 07:39:15.276] [D] [zway] RECEIVED: ( 01 07 00 13 19 00 00 07 F5 )
[2016-09-07 07:39:15.278] [D] [zway] SENT ACK
[2016-09-07 07:39:15.279] [I] [zway] Job 0x13 (Configuration Get): Delivered
[2016-09-07 07:39:15.281] [D] [zway] SETDATA devices.11.data.lastPacketInfo.delivered = True
[2016-09-07 07:39:15.282] [D] [zway] SETDATA devices.11.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-09-07 07:39:15.287] [D] [zway] SETDATA devices.11.data.lastPacketInfo.deliveryTime = 70 (0x00000046)
[2016-09-07 07:39:15.288] [D] [zway] SETDATA devices.11.data.lastPacketInfo = **********
[2016-09-07 07:39:15.289] [D] [zway] SendData Response with callback 0x19 received: received by recipient
[2016-09-07 07:39:15.291] [D] [zway] SETDATA devices.11.data.lastSend = 357942 (0x00057636)
[2016-09-07 07:39:15.292] [D] [zway] Job 0x13 (Configuration Get): success
[2016-09-07 07:39:15.293] [I] [zway] Removing job: Configuration Get
[2016-09-07 07:39:15.359] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0B 05 70 06 35 01 00 BC )
[2016-09-07 07:39:15.359] [D] [zway] SENT ACK
[2016-09-07 07:39:15.360] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-09-07 07:39:15.360] [D] [zway] SETDATA devices.11.instances.0.commandClasses.112.data.53.size = 1 (0x00000001)
[2016-09-07 07:39:15.360] [D] [zway] SETDATA devices.11.instances.0.commandClasses.112.data.53.val = 0 (0x00000000)
[2016-09-07 07:39:15.360] [D] [zway] SETDATA devices.11.instances.0.commandClasses.112.data.53 = Empty
[2016-09-07 07:39:15.360] [I] [zway] Node 11:0 CC Configuration: Parameter 0x35 = 0 (size = 1)
