HYT221 Temperatur / Humidity I2C Sensor
mdietinger@gmail.com
Post by mdietinger@gmail.com »
:idea: Hello,
tested the HYT221 high accuracy temperatur and humidity I2C Sensor.
The wiring:
Z-UNO PIN 10 -> PIN1
Z-UNO PIN GND -> PIN2
Z-UNO PIN 3.3V -> PIN3
Z-UNO PIN 9 -> PIN4
The code:
// demo sketch for connecting HYT221 humidity and temperature sensor to Z-Uno
// add library
#include <Wire.h>
// set up channels
ZUNO_SETUP_CHANNELS(
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL,
                          getterTemperature),
     ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidity)
void setup() {
  #define HYT_ADDR 0x28     // I2C address of the HYT 221, 271, 939 and most likely the rest of the family
  Wire.begin();             // Join I2c Bus as master
  Serial.begin(9600);       // Start serial communication for serial console output
  pinMode(13, OUTPUT);
int humidity; // here we will store the humidity
word temperature; // here we will store the temperature
void loop() {
  int iData[4];
  Wire.beginTransmission(HYT_ADDR);
  Wire.write(0);    // initiate measurement
  Wire.endTransmission();
  delay(500);
  Wire.beginTransmission(HYT_ADDR);   // Begin transmission with given device on I2C bus
  Wire.requestFrom(HYT_ADDR, 4);      // Request 4 bytes
  // Read the bytes if they are available
  // The first two bytes are humidity the last two are temperature
  if(Wire.available() == 4) {
           iData[1] = Wire.read();
           iData[2] = Wire.read();
           iData[3] = Wire.read();
           iData[4] = Wire.read();
           Wire.endTransmission();           // End transmission and release I2C bus
           // combine humidity bytes and calculate humidity
           int rawHumidity = iData[1] << 8 | iData[2];
           rawHumidity =  (rawHumidity &= 0x3FFF);
           humidity = 100.0 / pow(2,14) * rawHumidity;
        Serial.print("Humidity: ");
        Serial.print(humidity);
          // combine temperature bytes and calculate temperature
          iData[4] = (iData[4] >> 2); // Mask away 2 least significant bits see HYT 221 doc
          int rawTemperature = iData[3] << 6 | iData[4];
          temperature = (165.0 / pow(2,14) * rawTemperature - 40)*10;
        Serial.print("% - Temperature: ");
        Serial.print(temperature/10);
        Serial.println("C");
  else {
        Serial.println("Not enough bytes available on wire.");
  zunoSendReport(1);
  zunoSendReport(2);
  blinkWait();
 delay(28000);// send every 30 second
  void blinkWait() {
  digitalWrite(13, HIGH);
  delay(1000);
  digitalWrite(13, LOW);
  delay(1000);
word getterTemperature() {
  return temperature;
byte getterHumidity() {
  return humidity;
Re: HYT221 Temperatur / Humidity I2C Sensor
Works?
Can we publish it on Ecamples page with credits to you?
Could you please make a photo of schematics and may be a Fritzing (if not too painful).
PoltS,
works like a charm :D
Sure you can publish on examples page, but wasn't 100% my creation.
Did copy and paste out of examples for UNO and adjust to get it working on Z-UNO.
Only thing to note, the sensor requires the updated wire library to get reported all 4 values. (BMP180 fix)
Over the weekend I will test as well HYT939 (better mechanical robustness).
Then I will provide pictures and Fritzing for both sensors.
I will post as well a code to change I2C address for HYTxxx. (Did work on HYT221)
