z-way-server crashes
FrankR
Post by FrankR »
this morning my z-way-server crashed for unknown reason. I can't see any error in the log. I tried to restart the server several times but after a few seconds it goes down again.
What can I do? I made a backup a few days ago. But how can I restore it without the server running?
EDIT: Can't discover any problems with the pi itself:
df -h shows a maximum of 39%
cpu is at 4% workload
ram is at 9% workload
temperature is below 45°C
apt-get update -> no problem
apt-get upgrade -> no problem
/EDIT
EDIT:
After disconnecting the RaZberry board the z-way-server came up again. Then I connected the board again, restartet my pi and the server. The server again went down after 13 seconds. Guess my RaZberry board is crrupt. Can I verify this in anyway?
/EDIT
Here are the last lines from the server log:
[2016-11-20 14:21:43.246] [I] [core] Loading module WeatherUnderground from modules/WeatherUnderground
[2016-11-20 14:21:43.254] [I] [core] Executing script: /*** WeatherUnderground Z-Way HA module ******************************************* ...
[2016-11-20 14:21:43.263] [I] [core] Instantiating module 76 from class WeatherUnderground
[2016-11-20 14:21:43.266] [I] [core] --- Starting module WeatherUndergound module
[2016-11-20 14:21:43.293] [I] [core] Creating device sensorMultilevel WeatherUnderground_current_76
[2016-11-20 14:21:43.306] [I] [core] HK: added WeatherUnderground_current_76
[2016-11-20 14:21:43.312] [I] [core] Creating device sensorMultilevel WeatherUnderground_forecast_76
[2016-11-20 14:21:43.323] [I] [core] HK: added WeatherUnderground_forecast_76
[2016-11-20 14:21:43.329] [I] [core] Creating device sensorMultilevel WeatherUnderground_humidity_76
[2016-11-20 14:21:43.347] [I] [core] HK: added WeatherUnderground_humidity_76
[2016-11-20 14:21:43.355] [I] [core] Creating device sensorMultilevel WeatherUnderground_wind_76
[2016-11-20 14:21:43.364] [I] [core] HK: added WeatherUnderground_wind_76
[2016-11-20 14:21:43.370] [I] [core] Creating device sensorMultilevel WeatherUnderground_uv_76
[2016-11-20 14:21:43.381] [I] [core] HK: added WeatherUnderground_uv_76
[2016-11-20 14:21:43.386] [I] [core] Creating device sensorMultilevel WeatherUnderground_barometer_76
[2016-11-20 14:21:43.396] [I] [core] HK: added WeatherUnderground_barometer_76
[2016-11-20 14:21:43.402] [I] [core] [WeatherUnderground] Last update time 1479588201505
[2016-11-20 14:21:43.406] [I] [core] Loading module RoundRobinScenes from modules/RoundRobinScenes
[2016-11-20 14:21:43.407] [I] [core] Executing script: /*** RoundRobinScenes Z-Way HA module ******************************************* ...
[2016-11-20 14:21:43.409] [I] [core] Loading module FosCam9828 from modules/FosCam9828
[2016-11-20 14:21:43.411] [I] [core] Executing script: /*** FosCam9828 Z-Way HA module ******************************************* ...
[2016-11-20 14:21:43.414] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2016-11-20 14:21:43.416] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2016-11-20 14:21:43.430] [I] [core] Instantiating module 10 from class CodeDevice
[2016-11-20 14:21:43.433] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.458] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_10
[2016-11-20 14:21:43.470] [I] [core] HK: added Code_Device_switchMultilevel_10
[2016-11-20 14:21:43.484] [I] [core] Instantiating module 41 from class CodeDevice
[2016-11-20 14:21:43.484] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.546] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_41
[2016-11-20 14:21:43.557] [I] [core] HK: added Code_Device_switchMultilevel_41
[2016-11-20 14:21:43.566] [I] [core] Instantiating module 77 from class CodeDevice
[2016-11-20 14:21:43.566] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.591] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_77
[2016-11-20 14:21:43.602] [I] [core] HK: added Code_Device_switchMultilevel_77
[2016-11-20 14:21:43.611] [I] [core] Instantiating module 88 from class CodeDevice
[2016-11-20 14:21:43.611] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.636] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_88
[2016-11-20 14:21:43.648] [I] [core] HK: added Code_Device_switchMultilevel_88
[2016-11-20 14:21:43.657] [I] [core] Instantiating module 91 from class CodeDevice
[2016-11-20 14:21:43.657] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.688] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_91
[2016-11-20 14:21:43.701] [I] [core] HK: added Code_Device_switchMultilevel_91
[2016-11-20 14:21:43.711] [I] [core] Instantiating module 98 from class CodeDevice
[2016-11-20 14:21:43.711] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.927] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_98
[2016-11-20 14:21:43.939] [I] [core] HK: added Code_Device_switchMultilevel_98
[2016-11-20 14:21:43.950] [I] [core] Instantiating module 109 from class CodeDevice
[2016-11-20 14:21:43.950] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:43.974] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_109
[2016-11-20 14:21:43.994] [I] [core] HK: added Code_Device_switchMultilevel_109
[2016-11-20 14:21:44.004] [I] [core] Instantiating module 110 from class CodeDevice
[2016-11-20 14:21:44.004] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.028] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_110
[2016-11-20 14:21:44.044] [I] [core] HK: added Code_Device_switchMultilevel_110
[2016-11-20 14:21:44.053] [I] [core] Instantiating module 111 from class CodeDevice
[2016-11-20 14:21:44.053] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.077] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_111
[2016-11-20 14:21:44.090] [I] [core] HK: added Code_Device_switchMultilevel_111
[2016-11-20 14:21:44.101] [I] [core] Instantiating module 112 from class CodeDevice
[2016-11-20 14:21:44.102] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.132] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_112
[2016-11-20 14:21:44.152] [I] [core] HK: added Code_Device_switchMultilevel_112
[2016-11-20 14:21:44.161] [I] [core] Instantiating module 113 from class CodeDevice
[2016-11-20 14:21:44.161] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.186] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_113
[2016-11-20 14:21:44.199] [I] [core] HK: added Code_Device_switchMultilevel_113
[2016-11-20 14:21:44.210] [I] [core] Instantiating module 114 from class CodeDevice
[2016-11-20 14:21:44.210] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.234] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_114
[2016-11-20 14:21:44.238] [D] [zway] RECEIVED: ( 01 07 00 13 03 01 01 2D C5 )
[2016-11-20 14:21:44.238] [D] [zway] SENT ACK
[2016-11-20 14:21:44.238] [I] [zway] Job 0x13 (MultiCmd, Clock Report, Schedule Change Report (schedule change mechanism disabled)): Callback received - transfered to encapsulated jobs
[2016-11-20 14:21:44.239] [I] [zway] Job 0x13 (Clock Report): Not delivered to recipient
[2016-11-20 14:21:44.239] [I] [zway] Job 0x13 (Schedule Change Report (schedule change mechanism disabled)): Not delivered to recipient
[2016-11-20 14:21:44.239] [I] [zway] Job 0x13 (MultiCmd, Clock Report, Schedule Change Report (schedule change mechanism disabled)): Not delivered to recipient
[2016-11-20 14:21:44.239] [D] [zway] SETDATA devices.18.data.lastPacketInfo.delivered = False
[2016-11-20 14:21:44.239] [D] [zway] SETDATA devices.18.data.lastPacketInfo.packetLength = 15 (0x0000000f)
[2016-11-20 14:21:44.239] [D] [zway] SETDATA devices.18.data.lastPacketInfo.deliveryTime = 3007 (0x00000bbf)
[2016-11-20 14:21:44.239] [D] [zway] SETDATA devices.18.data.lastPacketInfo = **********
[2016-11-20 14:21:44.239] [D] [zway] SETDATA devices.18.data.isAwake = False
[2016-11-20 14:21:44.239] [D] [zway] Sending the queue for node 18 into sleep
[2016-11-20 14:21:44.250] [I] [core] HK: added Code_Device_switchMultilevel_114
[2016-11-20 14:21:44.260] [I] [core] Instantiating module 124 from class CodeDevice
[2016-11-20 14:21:44.260] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.290] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_124
[2016-11-20 14:21:44.303] [I] [core] HK: added Code_Device_switchMultilevel_124
[2016-11-20 14:21:44.312] [I] [core] Instantiating module 132 from class CodeDevice
[2016-11-20 14:21:44.313] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.342] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_132
[2016-11-20 14:21:44.356] [I] [core] HK: added Code_Device_switchMultilevel_132
[2016-11-20 14:21:44.366] [I] [core] Instantiating module 137 from class CodeDevice
[2016-11-20 14:21:44.366] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.390] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_137
[2016-11-20 14:21:44.409] [I] [core] HK: added Code_Device_switchMultilevel_137
[2016-11-20 14:21:44.419] [I] [core] Instantiating module 140 from class CodeDevice
[2016-11-20 14:21:44.420] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.444] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_140
[2016-11-20 14:21:44.459] [I] [core] HK: added Code_Device_switchMultilevel_140
[2016-11-20 14:21:44.468] [I] [core] Instantiating module 141 from class CodeDevice
[2016-11-20 14:21:44.468] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.498] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_141
[2016-11-20 14:21:44.517] [I] [core] HK: added Code_Device_switchMultilevel_141
[2016-11-20 14:21:44.526] [I] [core] Instantiating module 153 from class CodeDevice
[2016-11-20 14:21:44.526] [I] [core] --- Starting module Code Device
[2016-11-20 14:21:44.551] [I] [core] Creating device switchMultilevel Code_Device_switchMultilevel_153
[2016-11-20 14:21:44.567] [I] [core] HK: added Code_Device_switchMultilevel_153
[2016-11-20 14:21:44.573] [I] [core] Loading module HTTPDevice from modules/HTTPDevice
[2016-11-20 14:21:44.576] [I] [core] Executing script: /*** HTTPDevice Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.577] [I] [core] Loading module Sonos from modules/Sonos
[2016-11-20 14:21:44.581] [I] [core] Executing script: /*** Sonos Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.583] [I] [core] Loading module AutoOff from modules/AutoOff
[2016-11-20 14:21:44.584] [I] [core] Executing script: /*** AutoOff Z-Way Home Automation module ************************************* ...
[2016-11-20 14:21:44.586] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2016-11-20 14:21:44.587] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.589] [I] [core] Loading module BindDevices from modules/BindDevices
[2016-11-20 14:21:44.590] [I] [core] Executing script: /*** BindDevices Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.591] [I] [core] Loading module RandomDevice from modules/RandomDevice
[2016-11-20 14:21:44.594] [I] [core] Executing script: /*** RandomDevice Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.597] [I] [core] Loading module DeviceHistory from modules/DeviceHistory
[2016-11-20 14:21:44.600] [I] [core] Executing script: /*** DeviceHistory Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.601] [I] [core] Loading module FosCam9805 from modules/FosCam9805
[2016-11-20 14:21:44.603] [I] [core] Executing script: /*** FosCam9805 Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.605] [I] [core] Loading module Presence from modules/Presence
[2016-11-20 14:21:44.608] [I] [core] Executing script: /*** Presence Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.613] [I] [core] Instantiating module 102 from class Presence
[2016-11-20 14:21:44.614] [I] [core] --- Starting module Presence state
[2016-11-20 14:21:44.642] [I] [core] Creating device switchBinary Presence_presence_102
[2016-11-20 14:21:44.660] [I] [core] HK: added Presence_presence_102
[2016-11-20 14:21:44.719] [I] [core] Creating device switchBinary Presence_vacation_102
[2016-11-20 14:21:44.748] [I] [core] HK: added Presence_vacation_102
[2016-11-20 14:21:44.801] [I] [core] Creating device switchBinary Presence_night_102
[2016-11-20 14:21:44.818] [I] [core] HK: added Presence_night_102
[2016-11-20 14:21:44.881] [I] [core] Notification: error (core): Dependency not found for module: [DEP]::[MODUL] = BaseModule :: ConditionSwitch
[2016-11-20 14:21:44.882] [I] [core] Loading module ThermostatControl from modules/ThermostatControl
[2016-11-20 14:21:44.886] [I] [core] Executing script: /*** ThermostatControl Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.888] [I] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2016-11-20 14:21:44.890] [I] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.892] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2016-11-20 14:21:44.895] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2016-11-20 14:21:44.899] [I] [core] Instantiating module 9 from class SwitchControlGenerator
[2016-11-20 14:21:44.904] [I] [core] --- Starting module Trap events from Remotes and Sensors
[2016-11-20 14:21:44.935] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_11-0-0
[2016-11-20 14:21:44.965] [I] [core] HK: added ZWayVDev_zway_Remote_11-0-0
[2016-11-20 14:21:44.971] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_13-0-0
[2016-11-20 14:21:44.995] [I] [core] HK: added ZWayVDev_zway_Remote_13-0-0
[2016-11-20 14:21:45.000] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_10-0-0
[2016-11-20 14:21:45.021] [I] [core] HK: added ZWayVDev_zway_Remote_10-0-0
[2016-11-20 14:21:45.026] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_15-0-7
[2016-11-20 14:21:45.044] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_15-0-5
[2016-11-20 14:21:45.067] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_15-0-2
[2016-11-20 14:21:45.085] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_15-0-3
[2016-11-20 14:21:45.112] [I] [core] Creating device buttonControl ZWayVDev_zway_Remote_17-0-0
[2016-11-20 14:21:45.138] [I] [core] HK: added ZWayVDev_zway_Remote_17-0-0
Need Help! :-(
Thanx in advance
Frank
FrankR
Re: z-way-server crashes
Post by FrankR »
Here is some more information:
During startup I found the following log entries
[2016-11-20 17:06:40.453] [D] [zway] Opened device: /dev/ttyAMA0
[2016-11-20 17:06:40.454] [D] [zway] Worker thread successfully created
[2016-11-20 17:06:40.454] [D] [zway] Worker thread entry point
[2016-11-20 17:06:40.462] [I] [zway] Adding job: Get controller info and supported function classes
[2016-11-20 17:06:40.465] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-11-20 17:06:40.466] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.475] [D] [zway] RECEIVED: ( 01 2B 01 07 05 00 01 47 04 00 00 01 FE 83 FF 88 CF 1F 00 00 FB 9F 7D A0 67 00 80 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 40 1A 00 59 )
[2016-11-20 17:06:40.475] [D] [zway] SENT ACK
[2016-11-20 17:06:40.475] [D] [zway] SETDATA controller.data.APIVersion = "05.00"
[2016-11-20 17:06:40.475] [D] [zway] SETDATA controller.data.manufacturerId = 327 (0x00000147)
[2016-11-20 17:06:40.475] [D] [zway] SETDATA controller.data.manufacturerProductType = 1024 (0x00000400)
[2016-11-20 17:06:40.475] [D] [zway] SETDATA controller.data.manufacturerProductId = 1 (0x00000001)
[2016-11-20 17:06:40.478] [D] [zway] SETDATA controller.data.vendor = "RaZberry by Z-Wave.Me"
[2016-11-20 17:06:40.478] [D] [zway] Supported Function Classes:
[2016-11-20 17:06:40.478] [D] [zway] ---------------------------
[2016-11-20 17:06:40.478] [D] [zway] 0x02 SerialAPIGetInitData
[2016-11-20 17:06:40.478] [D] [zway] 0x03 SerialAPIApplicationNodeInformation
[2016-11-20 17:06:40.478] [D] [zway] 0x04 ApplicationCommandHandler
[2016-11-20 17:06:40.478] [D] [zway] 0x05 GetControllerCapabilities
[2016-11-20 17:06:40.478] [D] [zway] 0x06 SerialAPISetTimeouts
[2016-11-20 17:06:40.478] [D] [zway] 0x07 GetSerialAPICapabilities
[2016-11-20 17:06:40.478] [D] [zway] 0x08 SerialAPISoftReset
[2016-11-20 17:06:40.479] [D] [zway] 0x09 UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x0a UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x10 UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x11 UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x12 SendNodeInformation
[2016-11-20 17:06:40.479] [D] [zway] 0x13 SendData
[2016-11-20 17:06:40.479] [D] [zway] 0x14 UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x15 GetVersion
[2016-11-20 17:06:40.479] [D] [zway] 0x16 SendDataAbort
[2016-11-20 17:06:40.479] [D] [zway] 0x17 RFPowerLevelSet
[2016-11-20 17:06:40.479] [D] [zway] 0x18 UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x1c UNKNOWN
[2016-11-20 17:06:40.479] [D] [zway] 0x20 GetHomeId
[2016-11-20 17:06:40.479] [D] [zway] 0x21 MemoryGetByte
[2016-11-20 17:06:40.479] [D] [zway] 0x22 MemoryPutByte
[2016-11-20 17:06:40.479] [D] [zway] 0x23 MemoryGetBuffer
[2016-11-20 17:06:40.479] [D] [zway] 0x24 MemoryPutBuffer
[2016-11-20 17:06:40.479] [D] [zway] 0x27 FlashAutoProgSet
[2016-11-20 17:06:40.480] [D] [zway] 0x28 UNKNOWN
[2016-11-20 17:06:40.480] [D] [zway] 0x29 NVMGetId
[2016-11-20 17:06:40.480] [D] [zway] 0x2a NVMExtReadLongBuffer
[2016-11-20 17:06:40.480] [D] [zway] 0x2b NVMExtWriteLongBuffer
[2016-11-20 17:06:40.480] [D] [zway] 0x2c NVMExtReadLongByte
[2016-11-20 17:06:40.480] [D] [zway] 0x2d NVMExtWriteLongByte
[2016-11-20 17:06:40.480] [D] [zway] 0x41 GetNodeProtocolInformation
[2016-11-20 17:06:40.480] [D] [zway] 0x42 SetDefault
[2016-11-20 17:06:40.480] [D] [zway] 0x44 ReplicationReceiveComplete
[2016-11-20 17:06:40.480] [D] [zway] 0x45 UNKNOWN
[2016-11-20 17:06:40.480] [D] [zway] 0x46 AssignReturnRoute
[2016-11-20 17:06:40.480] [D] [zway] 0x47 DeleteReturnRoute
[2016-11-20 17:06:40.480] [D] [zway] 0x48 RequestNodeNeighbourUpdate
[2016-11-20 17:06:40.480] [D] [zway] 0x49 ApplicationNodeUpdate
[2016-11-20 17:06:40.480] [D] [zway] 0x4a AddNodeToNetwork
[2016-11-20 17:06:40.480] [D] [zway] 0x4b RemoveNodeFromNetwork
[2016-11-20 17:06:40.480] [D] [zway] 0x4c CreateNewPrimary
[2016-11-20 17:06:40.480] [D] [zway] 0x4d ControllerChange
[2016-11-20 17:06:40.480] [D] [zway] 0x50 SetLearnMode
[2016-11-20 17:06:40.480] [D] [zway] 0x51 AssignSUCReturnRoute
[2016-11-20 17:06:40.480] [D] [zway] 0x53 RequestNetworkUpdate
[2016-11-20 17:06:40.481] [D] [zway] 0x54 SetSUCNodeId
[2016-11-20 17:06:40.481] [D] [zway] 0x55 DeleteSUCReturnRoute
[2016-11-20 17:06:40.481] [D] [zway] 0x56 GetSUCNodeId
[2016-11-20 17:06:40.481] [D] [zway] 0x57 SendSUCNodeId
[2016-11-20 17:06:40.481] [D] [zway] 0x5e UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x60 RequestNodeInformation
[2016-11-20 17:06:40.481] [D] [zway] 0x61 RemoveFailedNode
[2016-11-20 17:06:40.481] [D] [zway] 0x62 IsFailedNode
[2016-11-20 17:06:40.481] [D] [zway] 0x63 ReplaceFailedNode
[2016-11-20 17:06:40.481] [D] [zway] 0x66 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x67 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x78 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x80 GetRoutingTableLine
[2016-11-20 17:06:40.481] [D] [zway] 0x90 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x92 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x93 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0x98 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0xb4 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0xb6 UNKNOWN
[2016-11-20 17:06:40.481] [D] [zway] 0xb7 UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xb8 UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xb9 UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xba RFPowerLevelGet
[2016-11-20 17:06:40.482] [D] [zway] 0xbd UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xbe SendTestFrame
[2016-11-20 17:06:40.482] [D] [zway] 0xbf UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xd2 WatchDogStart
[2016-11-20 17:06:40.482] [D] [zway] 0xd3 WatchDogStop
[2016-11-20 17:06:40.482] [D] [zway] 0xd4 UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xef UNKNOWN
[2016-11-20 17:06:40.482] [D] [zway] 0xf2 ZMEFreqChange
[2016-11-20 17:06:40.482] [D] [zway] 0xf4 ZMEBootloaderFlash
[2016-11-20 17:06:40.482] [D] [zway] 0xf5 ZMECapabilities
[2016-11-20 17:06:40.482] [D] [zway] SETDATA controller.data.capabilities = int[79]
[2016-11-20 17:06:40.482] [D] [zway]   [00] 2
[2016-11-20 17:06:40.482] [D] [zway]   [01] 3
[2016-11-20 17:06:40.482] [D] [zway]   [02] 4
[2016-11-20 17:06:40.487] [D] [zway]   [77] 244
[2016-11-20 17:06:40.487] [D] [zway]   [78] 245
[2016-11-20 17:06:40.487] [D] [zway] ---------------------------
[2016-11-20 17:06:40.487] [D] [zway] Initialization done
[2016-11-20 17:06:40.487] [D] [zway] Job 0x07 (Get controller info and supported function classes): success
[2016-11-20 17:06:40.487] [I] [zway] Adding job: Get or set Z-Wave.Me firmware capabilities
[2016-11-20 17:06:40.487] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2016-11-20 17:06:40.487] [I] [zway] Adding job: Set Serial API timeouts
[2016-11-20 17:06:40.487] [I] [zway] Adding job: Set RF power level
[2016-11-20 17:06:40.487] [I] [zway] Adding job: WatchDog Start
[2016-11-20 17:06:40.487] [D] [zway] SETDATA controller.data.frequency = "unknown"
[2016-11-20 17:06:40.487] [E] [zway] Error returned from zway_fc_zme_freq_change(zway, 0xFF, NULL, NULL, NULL): Function class not supported by the hardware (-4)
[2016-11-20 17:06:40.487] [I] [zway] Adding job: Get home id and controller node id
[2016-11-20 17:06:40.488] [I] [zway] Removing job: Get controller info and supported function classes
[2016-11-20 17:06:40.488] [D] [zway] SENDING (cb 0x01): ( 01 04 00 F5 01 0F )
[2016-11-20 17:06:40.488] [W] [zway] Received SOF, while awaiting ACK
[2016-11-20 17:06:40.488] [D] [zway] RECEIVED: ( 01 1E 00 0A 05 01 01 02 01 15 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 07 )
[2016-11-20 17:06:40.488] [D] [zway] SENT ACK
[2016-11-20 17:06:40.488] [W] [zway] No job of class 0x0a is waiting for callback 0x05
[2016-11-20 17:06:40.488] [I] [zway] Unhandled callback for function 0x00
[2016-11-20 17:06:40.488] [I] [zway] Removing job: Unknown function class
[2016-11-20 17:06:40.489] [D] [zway] RECEIVED CAN
[2016-11-20 17:06:40.896] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): No ACK received before timeout
[2016-11-20 17:06:40.896] [D] [zway] SENDING (cb 0x01): ( 01 04 00 F5 01 0F )
[2016-11-20 17:06:40.898] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.899] [D] [zway] RECEIVED: ( 01 04 01 F5 CE C1 )
[2016-11-20 17:06:40.899] [D] [zway] SENT ACK
[2016-11-20 17:06:40.899] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2016-11-20 17:06:40.906] [D] [zway] RECEIVED: ( 01 25 00 F5 01 DA 64 4D 29 C3 78 9F 97 9E 4B F0 65 8C 43 9A 03 83 00 00 FF 01 00 00 00 00 00 00 00 00 00 00 00 00 2C )
[2016-11-20 17:06:40.906] [D] [zway] SENT ACK
[2016-11-20 17:06:40.907] [D] [zway] SETDATA controller.data.uuid = "644d29c3789f979e4bf0658c439a0383"
[2016-11-20 17:06:40.907] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Done
[2016-11-20 17:06:40.907] [D] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): success
[2016-11-20 17:06:40.907] [I] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
[2016-11-20 17:06:40.907] [D] [zway] SENDING: ( 01 05 00 06 0A 0A FC )
[2016-11-20 17:06:40.916] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.916] [D] [zway] RECEIVED: ( 01 05 01 06 96 0F 64 )
[2016-11-20 17:06:40.917] [D] [zway] SENT ACK
[2016-11-20 17:06:40.917] [I] [zway] Job 0x06 (Set Serial API timeouts): Old timeouts are: ACK timeout 1500 ms and Byte timeout 150 ms
[2016-11-20 17:06:40.917] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 150 (0x00000096)
[2016-11-20 17:06:40.917] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 15 (0x0000000f)
[2016-11-20 17:06:40.917] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = 10 (0x0000000a)
[2016-11-20 17:06:40.917] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = 10 (0x0000000a)
[2016-11-20 17:06:40.917] [D] [zway] Job 0x06 (Set Serial API timeouts): success
[2016-11-20 17:06:40.917] [I] [zway] Removing job: Set Serial API timeouts
[2016-11-20 17:06:40.917] [D] [zway] SENDING: ( 01 04 00 17 00 EC )
[2016-11-20 17:06:40.926] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.927] [D] [zway] RECEIVED: ( 01 04 01 17 00 ED )
[2016-11-20 17:06:40.927] [D] [zway] SENT ACK
[2016-11-20 17:06:40.927] [I] [zway] Job 0x17 (Set RF power level): Done
[2016-11-20 17:06:40.927] [D] [zway] Job 0x17 (Set RF power level): success
[2016-11-20 17:06:40.927] [I] [zway] Removing job: Set RF power level
[2016-11-20 17:06:40.927] [D] [zway] SENDING: ( 01 03 00 D2 2E )
[2016-11-20 17:06:40.936] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.936] [I] [zway] Removing job: WatchDog Start
[2016-11-20 17:06:40.947] [D] [zway] SENDING: ( 01 03 00 20 DC )
[2016-11-20 17:06:40.948] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.957] [D] [zway] RECEIVED: ( 01 08 01 20 F1 5E F0 0A 01 82 )
[2016-11-20 17:06:40.957] [D] [zway] SENT ACK
[2016-11-20 17:06:40.957] [D] [zway] SETDATA controller.data.nodeId = 1 (0x00000001)
[2016-11-20 17:06:40.957] [D] [zway] SETDATA controller.data.homeId = -245436406 (0xf15ef00a)
[2016-11-20 17:06:40.957] [I] [zway] Job 0x20 (Get home id and controller node id): Home id: 0xf15ef00a, controller node id: 1
[2016-11-20 17:06:40.957] [D] [zway] Job 0x20 (Get home id and controller node id): success
[2016-11-20 17:06:40.957] [I] [zway] Adding job: Get controller capabilities
[2016-11-20 17:06:40.957] [I] [zway] Adding job: Get controller version
[2016-11-20 17:06:40.958] [I] [zway] Adding job: Get SUC node id
[2016-11-20 17:06:40.958] [I] [zway] Adding job: Get initial data about network devices
[2016-11-20 17:06:40.958] [I] [zway] Removing job: Get home id and controller node id
[2016-11-20 17:06:40.958] [D] [zway] SENDING: ( 01 03 00 05 F9 )
[2016-11-20 17:06:40.967] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.967] [D] [zway] RECEIVED: ( 01 04 01 05 1C E3 )
[2016-11-20 17:06:40.967] [D] [zway] SENT ACK
[2016-11-20 17:06:40.968] [D] [zway] SETDATA controller.data.isPrimary = True
[2016-11-20 17:06:40.968] [D] [zway] SETDATA controller.data.isInOthersNetwork = False
[2016-11-20 17:06:40.968] [D] [zway] SETDATA controller.data.SISPresent = True
[2016-11-20 17:06:40.968] [D] [zway] SETDATA controller.data.isRealPrimary = True
[2016-11-20 17:06:40.968] [D] [zway] SETDATA controller.data.isSUC = True
[2016-11-20 17:06:40.968] [D] [zway] Job 0x05 (Get controller capabilities): success
[2016-11-20 17:06:40.968] [I] [zway] Removing job: Get controller capabilities
[2016-11-20 17:06:40.968] [D] [zway] SENDING: ( 01 03 00 15 E9 )
[2016-11-20 17:06:40.977] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.977] [D] [zway] RECEIVED: ( 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 39 00 01 95 )
[2016-11-20 17:06:40.978] [D] [zway] SENT ACK
[2016-11-20 17:06:40.979] [D] [zway] SETDATA controller.data.SDK = "6.51.03"
[2016-11-20 17:06:40.979] [D] [zway] SETDATA controller.data.ZWlibMajor = 3 (0x00000003)
[2016-11-20 17:06:40.979] [D] [zway] SETDATA controller.data.ZWlibMinor = 99 (0x00000063)
[2016-11-20 17:06:40.979] [D] [zway] SETDATA controller.data.ZWLib = 1 (0x00000001)
[2016-11-20 17:06:40.979] [D] [zway] SETDATA controller.data.libType = "Static Controller"
[2016-11-20 17:06:40.980] [D] [zway] Job 0x15 (Get controller version): success
[2016-11-20 17:06:40.980] [I] [zway] Removing job: Get controller version
[2016-11-20 17:06:40.980] [D] [zway] SENDING: ( 01 03 00 56 AA )
[2016-11-20 17:06:40.987] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:40.987] [D] [zway] RECEIVED: ( 01 04 01 56 01 AD )
[2016-11-20 17:06:40.987] [D] [zway] SENT ACK
[2016-11-20 17:06:40.987] [I] [zway] Job 0x56 (Get SUC node id): SUC node is 1
[2016-11-20 17:06:40.987] [D] [zway] SETDATA controller.data.SUCNodeId = 1 (0x00000001)
[2016-11-20 17:06:40.988] [D] [zway] Job 0x56 (Get SUC node id): success
[2016-11-20 17:06:40.988] [I] [zway] Removing job: Get SUC node id
[2016-11-20 17:06:40.988] [D] [zway] SENDING: ( 01 03 00 02 FE )
[2016-11-20 17:06:40.997] [D] [zway] RECEIVED ACK
[2016-11-20 17:06:41.048] [D] [zway] RECEIVED: ( 01 25 01 02 05 08 1D B5 BE 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 C4 )
[2016-11-20 17:06:41.048] [D] [zway] SENT ACK
[2016-11-20 17:06:41.048] [D] [zway] SETDATA controller.data.ZWVersion = 5 (0x00000005)
[2016-11-20 17:06:41.049] [D] [zway] SETDATA controller.data.ZWaveChip = "ZW0500"
[2016-11-20 17:06:41.049] [D] [zway] Capabilities:
[2016-11-20 17:06:41.049] [D] [zway] - Controller API
[2016-11-20 17:06:41.049] [D] [zway] - Timer function not supported
[2016-11-20 17:06:41.049] [D] [zway] - Primary Controller
[2016-11-20 17:06:41.049] [D] [zway] - Some reserved bits (0x08)
[2016-11-20 17:06:41.049] [D] [zway] Detected Devices:
[2016-11-20 17:06:41.049] [D] [zway] -----------------
[2016-11-20 17:06:41.049] [D] [zway] Node 0x01
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.data = Empty
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data = Empty
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.dynamic = Empty
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.dynamic = False
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.genericType = Empty
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.genericType = 0 (0x00000000)
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.specificType = Empty
[2016-11-20 17:06:41.049] [D] [zway] SETDATA devices.1.instances.0.data.specificType = 0 (0x00000000)
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.basicType = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.genericType = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.specificType = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.infoProtocolSpecific = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.deviceTypeString = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.isVirtual = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.isListening = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.isRouting = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.isAwake = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.optional = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.isFailed = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.beam = Empty
[2016-11-20 17:06:41.050] [D] [zway] SETDATA devices.1.data.sensor250 = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.sensor1000 = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.neighbours = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.manufacturerId = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.vendorString = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.manufacturerProductType = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.manufacturerProductId = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.ZWLib = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.ZWProtocolMajor = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.ZWProtocolMinor = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.SDK = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.applicationMajor = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.applicationMinor = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.nodeInfoFrame = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.ZDDXMLFile = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.lastSend = Empty
[2016-11-20 17:06:41.051] [D] [zway] SETDATA devices.1.data.lastNonceGet = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.lastReceived = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.failureCount = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.keepAwake = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.countSuccess = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.countFailed = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.queueLength = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.givenName = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.lastPacketInfo = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.lastPacketInfo.deliveryTime = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.lastPacketInfo.delivered = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.lastPacketInfo.packetLength = Empty
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.basicType = 0 (0x00000000)
[2016-11-20 17:06:41.052] [D] [zway] SETDATA devices.1.data.genericType = 0 (0x00000000)
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.specificType = 0 (0x00000000)
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.infoProtocolSpecific = 0 (0x00000000)
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.deviceTypeString = ""
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.isVirtual = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.isListening = True
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.isRouting = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.isAwake = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.optional = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.isFailed = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.beam = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.sensor250 = False
[2016-11-20 17:06:41.053] [D] [zway] SETDATA devices.1.data.sensor1000 = False
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.neighbours = Empty
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.manufacturerId = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.manufacturerProductType = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.manufacturerProductId = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.applicationMajor = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.applicationMinor = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.ZWProtocolMajor = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.ZWProtocolMinor = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.ZWLib = 0 (0x00000000)
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.SDK = ""
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.vendorString = ""
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.nodeInfoFrame = Empty
[2016-11-20 17:06:41.054] [D] [zway] SETDATA devices.1.data.ZDDXMLFile = ""
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.keepAwake = False
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.countSuccess = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.countFailed = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.queueLength = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.lastReceived = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.lastSend = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.failureCount = 0 (0x00000000)
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.1.data.givenName = ""
[2016-11-20 17:06:41.055] [I] [zway] Adding job: Get node protocol information
[2016-11-20 17:06:41.055] [I] [zway] Adding job: Get routing table line
[2016-11-20 17:06:41.055] [D] [zway] Job 0x80 (Get routing table line): removing duplicate
[2016-11-20 17:06:41.055] [D] [zway] Node 0x03
[2016-11-20 17:06:41.055] [D] [zway] SETDATA devices.3.data = Empty
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data = Empty
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data.dynamic = Empty
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data.dynamic = False
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data.genericType = Empty
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data.genericType = 0 (0x00000000)
[2016-11-20 17:06:41.056] [D] [zway] SETDATA devices.3.instances.0.data.specificType = Empty
In the beginning everything looks fine. But alter the data of every device ist "Empty"
FrankR
Post by FrankR »
Another addition:
The RaZberry board is ok, which I found out withe the help of anoterh pi. But although I restored my last .zbk backup all apps are still gone. How can I retrieve them from my other pi which seems to have a problem?
micky1500
Post by micky1500 »
Do you have the other backup to restore ? the .zab backup
Could try copying the server folder instead from the broken Pi
/opt/z-way-server
or copy one of the older server folders from the /opt folder to /opt/z-way-server
Or wait for an Expert to reply sometime soon hopefully :)
Raspi 4 - (Buster - 32 Bit) Zwave Version 4.1.1, Raz 7 Pro, Serial API Version: 07.38
FrankR
Post by FrankR »
Thanx so far micky. No, I don't have the .zab backup.
I copied the /opt/z-way-server folder to the second pi. But this also caused the same problems. The other folders in /opt are much too old :-(
Hope anyone can help repairing the files in /opt/z-way-server folder. Seems that only two of them are from today:
configjson-06b2d3b23dce96e1619d2b53d6c947ec.json
RaZberry-a5f9fbc303b7d5d74f99c840f738b01f.json
FrankR
Post by FrankR »
Any suggestions?
The configjson.xxx.json file seems to contain all my apos. How can I find out what is wrong in there?
