Disabled function in v2.2.5?
ClausE
Post by ClausE »
When upgrading from v2.2.4 to v2.2.5 some functions stopped working as expected.
1. I’m using the module send Email. (https://github.com/islipfd19/home-autom ... ules/Email) After upgrading and when trying to send a mail I get the fault message “Error during perform command execution: Error: This command is denied by policy”. When reverting back to an old backup and v2.2.4 everything is working correct again. Do I need to change anything to get the module working or is a bug in the new version?
2. I also have a Fibaro magic eye FGMS-001 V3.2 and at every battery polling (7200s) I get the motion detection alarm. I’m not absolutely sure if it is 100% consequent.
Unfortunately, I did not save any logs before reverting back to v2.2.4 (I had a complete Image+Zwave backup).
Have I done something wrong?.
marco
Re: Disabled function in v2.2.5?
Post by marco »
only for the point n 1, when you receive an error saying: "this command is denied by the policy" probably you are running an OS system call. To avoid this error you must specify the root of the command in the .syscommands file in the automation folder.
Marco
klaasjoerg
Post by klaasjoerg »
Yes, that's correct. The file .syscommands is unfortunately always overwritten/replaced once you upgraded your zwave-installation. So I usually backup this file, before doing an upgrade...
