Razberry v2 dont work change frequency to US
trackerit
Post by trackerit »
Just received the new board (stamped with a U) and installed in a new Raspberry Pi3. Loaded with 2.2.5 and I can change the frequency to US but it doesn't survive a reboot. Once bounced, it's back to RU. Going to 2.2.3 is obviously not an option as I cannot change to anything other than 'RU'.
all device zwave a try add is US frequency but it not working. a try reinstall the raspbian With several versions, but nowhere has it worked, I have a device that works on the RU frequency And adding it works but any device in US frequency not.
at reboot the server-log show its:
[2016-11-25 19:19:57.501] [D] [zway] SETDATA controller.data.frequency = "RU"
[2016-11-25 19:19:57.501] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): Done
[2016-11-25 19:19:57.501] [D] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): success
[2016-11-25 19:19:57.501] [zway] Removing job: Change/Get Z-Wave.Me firmware frequency
I do not know what to do
Grateful for any help you can give me...
Z-Wave Support
Re: Razberry v2 dont work change frequency to US
Post by Z-Wave Support »
you cannot a RU Controller change to US.
You can only change to EU,IN,CN or MY
Best regards
Z-Wave Support
trackerit
Post by trackerit »
the controller stamped with a U, on the chip... i solved the problem, I change the frequency to US and later in the app mobile ADD the device.
There is a problem in the f/w that it reports incorrectly RU while it is on US. Don't worry, everything should work.
If you update to 5.04 f/w (if you are not on it), it will be solved automatically.
