Hello everyone,
I'm having trouble establishing a stable communication between the an AVR and Z-Uno using the Wire library. I was trying to use the AVR for ADC readings (as the ADC of the Z-Uno currently doesn't work after Wakeup). However, I'm having the following problems:
* If I run the AVR at 16Mhz, the communication randomly works or doesn't work. I would say it works in about 80% of the cases.
* If I run the AVR at 8Mhz (which is the maximum for 3.3V according to the manual), the communication always fails.
There are no communication problems when I use the an Arduino Due as communication partner instead of the Z-Uno (at both 8 and 16Mhz), so it seems like the problem is rooted in the I2C implementation of the Z-Uno.
I have connected SDA, SCL and GND using jumper wires. Any ideas?
Unstable I2C communication
Re: Unstable I2C communication
Never try Arduino with Z-Uno as I2C slave. So, looks like it's time to do it... Anyway we fixed some problems during 2.0.7 in I2C already.
I will try your case before 2.0.8 release. Thank you.
To make it clear, in my setup the Z-Uno was the Master and the Atmega328p was the slave.
I tried fixed Wire library with this:
Sketch that uploaded to my Arduino Mega 2560(I2C slave):
Sketch uploded to Z-Uno (I2C Master):
They works great together now. We found problems with time intervals in I2C and fixed them. I tested updated Wire library with Arduino as slave, PN532 NFC reader (hope, we soon release library for it), AM2320 i2c temperature/humidity sensor (library will be added in 2.0.8) and it works correct in all cases.
#include <Wire.h>
#define COMMAND_READADC 0x40
#define COMMAND_PININ 0x20
#define COMMAND_PINOUTLOW 0x30
#define COMMAND_PINOUTHIGH 0x50
#define COMMAND_PINGET 0x70
void setup() {
Wire.begin(8); // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
Wire.onReceive(receiveEvent);
Serial.begin(115200);
Serial.println("Starting...");
void loop() {
delay(100);
int last_result = 0;
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
if(Wire.available())
byte c = Wire.read();
byte pin = c &0x0F;
c &= 0xF0;
last_result = 0;
switch(c)
case COMMAND_READADC:
last_result = analogRead(A0+pin);
break;
case COMMAND_PININ:
last_result = 1;
pinMode(pin, INPUT_PULLUP);
break;
case COMMAND_PINOUTLOW:
last_result = 1;
pinMode(pin, OUTPUT);
digitalWrite(pin, 0);
break;
case COMMAND_PINOUTHIGH:
last_result = 1;
digitalWrite(pin, 1);
break;
case COMMAND_PINGET:
last_result = digitalRead(pin);
break;
void requestEvent() {
char my_buff[2];
my_buff[0] = last_result >> 8;
my_buff[1] = last_result & 0xFF;
Wire.write(my_buff, 2);
#include <Wire.h>
#define MEGA_I2C_ADDR 8
#define MY_SERIAL Serial0
void setup() {
Wire.begin(); // join i2c bus with address #8
MY_SERIAL.begin(115200);
MY_SERIAL.println("Sketch is starting...");
byte last_error = 0;
word readADC(byte pin)
word adc_val;
Wire.beginTransmission(MEGA_I2C_ADDR);
Wire.write(COMMAND_READADC | (pin & 0x0F));
last_error = Wire.endTransmission();
if(last_error != 0)
return 0xFFFF;
Wire.requestFrom(MEGA_I2C_ADDR, 2);
adc_val = Wire.read();
adc_val <<= 8;
adc_val |= Wire.read();
return adc_val;
word pinONOFF(byte pin, byte onoff)
if(onoff)
Wire.write(COMMAND_PINOUTHIGH | (pin & 0x0F));
else
Wire.write(COMMAND_PINOUTLOW | (pin & 0x0F));
byte g_counter =0;
void loop() {
pinONOFF(13, g_counter & 0x08);
if(last_error != 0)
MY_SERIAL.print("I2C bus error (pinONOFF): ");
MY_SERIAL.println(last_error);
byte i;
for(i=0;i<7;i++)
word w = readADC(i);
MY_SERIAL.print("ADC ");
MY_SERIAL.print(i);
MY_SERIAL.print(" value:");
MY_SERIAL.println(w, HEX);
g_counter++;
delay(100);
ianakapilotlight
Does your code for the z-uno and arduino mega 2560 use all the available digitial & analogue pins on the mega 2560?
