ID Lock 101 no status update
Provo
Post by Provo »
I have a door lock called ID Lock 101 that seems to work perfectly, except that the status of the device isn't updated to unlocked ever. If I unlock it manually or with the Z-Way interface, it never shows as unlocked.
This is the log when manually unlocking the door:
[2017-03-04 09:14:44.295] [D] [zway] RECEIVED: ( 01 21 00 04 00 15 1B 98 81 E2 FD 3C B3 4B 2C A5 CE 9B 43 3A FB AE B4 99 11 1E ED 95 C3 F2 8B CC 0B 33 F2 )
[2017-03-04 09:14:44.295] [D] [zway] SENT ACK
[2017-03-04 09:14:44.296] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:14:44.296] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:14:44.297] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-04 09:14:44.297] [I] [zway] Node 21:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 03 fe fe ]
[2017-03-04 09:14:44.297] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-03-04 09:14:44.297] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-04 09:14:44.297] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-04 09:14:44.297] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.condition = 3 (0x00000003)
[2017-03-04 09:14:44.298] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-04 09:14:44.298] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-03-04 09:14:47.068] [D] [zway] RECEIVED: ( 01 21 00 04 10 15 1B 98 81 E2 FD 3C B3 4B 2C A5 CE 9B 43 3A FB AE B4 99 11 1E ED 95 C3 F2 8B CC 0B 33 E2 )
[2017-03-04 09:14:47.068] [D] [zway] SENT ACK
[2017-03-04 09:14:47.068] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:14:47.068] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:14:47.070] [W] [zway] Node 21:0 CC Security: can not decrypt packet due to nonce lookup problem
[2017-03-04 09:14:49.455] [D] [zway] RECEIVED: ( 01 07 00 13 FA 00 03 BF AD )
[2017-03-04 09:14:49.455] [D] [zway] SENT ACK
[2017-03-04 09:14:49.455] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-04 09:14:49.455] [D] [zway] SendData Response with callback 0xfa received: received by recipient
[2017-03-04 09:14:49.455] [D] [zway] SETDATA devices.21.data.lastSend = 55635021 (0x0350ec4d)
[2017-03-04 09:14:49.455] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-04 09:14:49.455] [I] [zway] Removing job: Nonce Report
[2017-03-04 09:14:58.559] [D] [zway] Job 0x13: deleted from queue
This is the log when unlocking from the Z-Way interface:
[2017-03-04 09:25:14.850] [I] [core] ---  ZWayVDev_zway_21-0-98 performCommand processing: {"0":"open","1":{}}
[2017-03-04 09:25:14.851] [I] [zway] Adding job: Door Lock Operation Set
[2017-03-04 09:25:14.855] [I] [zway] Adding job: Door Lock Operation Get
[2017-03-04 09:25:14.856] [I] [zway] Node 21:0 CC Security: sending Nonce Get
[2017-03-04 09:25:14.857] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-04 09:25:14.857] [I] [zway] Adding job: Nonce Get
[2017-03-04 09:25:14.857] [D] [zway] SETDATA devices.21.data.lastNonceGet = 55696204 (0x0351db4c)
[2017-03-04 09:25:14.867] [D] [zway] SENDING (cb 0x6c): ( 01 09 00 13 15 02 98 40 05 6C 43 )
[2017-03-04 09:25:14.869] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:14.873] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:14.873] [D] [zway] SENT ACK
[2017-03-04 09:25:14.873] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:16.461] [D] [zway] RECEIVED: ( 01 07 00 13 6C 00 00 9F 18 )
[2017-03-04 09:25:16.461] [D] [zway] SENT ACK
[2017-03-04 09:25:16.462] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-04 09:25:16.462] [D] [zway] SendData Response with callback 0x6c received: received by recipient
[2017-03-04 09:25:16.462] [D] [zway] SETDATA devices.21.data.lastSend = 55696362 (0x0351dbea)
[2017-03-04 09:25:16.462] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-04 09:25:16.462] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-04 09:25:16.462] [D] [zway] SETDATA devices.21.data.lastNonceGet = 55696362 (0x0351dbea)
[2017-03-04 09:25:16.462] [I] [zway] Removing job: Nonce Get
[2017-03-04 09:25:16.647] [D] [zway] RECEIVED: ( 01 10 00 04 00 15 0A 98 80 91 99 63 E3 5A 40 DD 36 95 )
[2017-03-04 09:25:16.647] [D] [zway] SENT ACK
[2017-03-04 09:25:16.648] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:16.648] [I] [zway] Node 21:0 CC Security: received Nonce Report
[2017-03-04 09:25:16.648] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-04 09:25:16.648] [I] [zway] Node 21:0 CC Security: Sending a secure message
[2017-03-04 09:25:16.648] [I] [zway] Node 21:0 CC Security: sending encrypted packet: Door Lock Operation Set
[2017-03-04 09:25:16.651] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.toFollow = False
[2017-03-04 09:25:16.652] [D] [zway] SETDATA devices.21.data.lastNonceGet = Empty
[2017-03-04 09:25:16.652] [I] [zway] Adding job: Security, Door Lock Operation Set
[2017-03-04 09:25:16.652] [I] [zway] Node 21:0 CC Security: sending Nonce Get
[2017-03-04 09:25:16.652] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-04 09:25:16.653] [I] [zway] Adding job: Nonce Get
[2017-03-04 09:25:16.653] [D] [zway] SETDATA devices.21.data.lastNonceGet = 55696380 (0x0351dbfc)
[2017-03-04 09:25:16.653] [D] [zway] SENDING (cb 0x6d): ( 01 1E 00 13 15 17 98 81 2C 38 48 42 FD 64 C6 50 00 BC 2E 52 91 3D F7 AD 1E B3 EA 9D 51 05 6D 2D )
[2017-03-04 09:25:16.657] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:16.660] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:16.661] [D] [zway] SENT ACK
[2017-03-04 09:25:16.661] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Response received - transfered to encapsulated jobs
[2017-03-04 09:25:16.661] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:19.557] [D] [zway] RECEIVED: ( 01 07 00 13 6D 00 01 22 A5 )
[2017-03-04 09:25:19.557] [D] [zway] SENT ACK
[2017-03-04 09:25:19.557] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Callback received - transfered to encapsulated jobs
[2017-03-04 09:25:19.557] [I] [zway] Job 0x13 (Door Lock Operation Set): Delivered
[2017-03-04 09:25:19.557] [D] [zway] SendData Response with callback 0x6d received: received by recipient
[2017-03-04 09:25:19.557] [D] [zway] Job 0x13 (Door Lock Operation Set): success
[2017-03-04 09:25:19.557] [I] [zway] Removing job: Door Lock Operation Set
[2017-03-04 09:25:19.557] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Delivered
[2017-03-04 09:25:19.558] [D] [zway] SendData Response with callback 0x6d received: received by recipient
[2017-03-04 09:25:19.558] [D] [zway] SETDATA devices.21.data.lastSend = 55696662 (0x0351dd16)
[2017-03-04 09:25:19.558] [D] [zway] Job 0x13 (Security, Door Lock Operation Set): success
[2017-03-04 09:25:19.558] [I] [zway] Removing job: Security, Door Lock Operation Set
[2017-03-04 09:25:19.627] [D] [zway] SENDING (cb 0x6e): ( 01 09 00 13 15 02 98 40 05 6E 41 )
[2017-03-04 09:25:19.629] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:19.633] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:19.633] [D] [zway] SENT ACK
[2017-03-04 09:25:19.633] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:19.711] [D] [zway] RECEIVED: ( 01 07 00 13 6E 00 00 08 8D )
[2017-03-04 09:25:19.712] [D] [zway] SENT ACK
[2017-03-04 09:25:19.712] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-04 09:25:19.712] [D] [zway] SendData Response with callback 0x6e received: received by recipient
[2017-03-04 09:25:19.712] [D] [zway] SETDATA devices.21.data.lastSend = 55696677 (0x0351dd25)
[2017-03-04 09:25:19.712] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-04 09:25:19.712] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-04 09:25:19.712] [D] [zway] SETDATA devices.21.data.lastNonceGet = 55696677 (0x0351dd25)
[2017-03-04 09:25:19.712] [I] [zway] Removing job: Nonce Get
[2017-03-04 09:25:19.792] [D] [zway] RECEIVED: ( 01 10 00 04 00 15 0A 98 80 32 FC 64 C8 AF 1B 52 EE 86 )
[2017-03-04 09:25:19.792] [D] [zway] SENT ACK
[2017-03-04 09:25:19.792] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:19.792] [I] [zway] Node 21:0 CC Security: received Nonce Report
[2017-03-04 09:25:19.792] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-04 09:25:19.792] [I] [zway] Node 21:0 CC Security: Sending a secure message
[2017-03-04 09:25:19.792] [I] [zway] Node 21:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-03-04 09:25:19.805] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.toFollow = False
[2017-03-04 09:25:19.805] [D] [zway] SETDATA devices.21.data.lastNonceGet = Empty
[2017-03-04 09:25:19.805] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-03-04 09:25:19.805] [D] [zway] SENDING (cb 0x6f): ( 01 1D 00 13 15 16 98 81 BE 0F FD F6 3D DB 7A DA E4 4C 4A 32 EF 4D D3 B3 25 25 80 52 05 6F BD )
[2017-03-04 09:25:19.809] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:19.813] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:19.813] [D] [zway] SENT ACK
[2017-03-04 09:25:19.813] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-03-04 09:25:19.813] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:19.989] [D] [zway] RECEIVED: ( 01 07 00 13 6F 00 00 11 95 )
[2017-03-04 09:25:19.989] [D] [zway] SENT ACK
[2017-03-04 09:25:19.991] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-03-04 09:25:19.991] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-03-04 09:25:19.991] [D] [zway] SendData Response with callback 0x6f received: received by recipient
[2017-03-04 09:25:19.991] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-03-04 09:25:19.991] [I] [zway] Removing job: Door Lock Operation Get
[2017-03-04 09:25:19.991] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-03-04 09:25:19.992] [D] [zway] SendData Response with callback 0x6f received: received by recipient
[2017-03-04 09:25:19.992] [D] [zway] SETDATA devices.21.data.lastSend = 55696704 (0x0351dd40)
[2017-03-04 09:25:19.992] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-03-04 09:25:19.992] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-03-04 09:25:20.915] [D] [zway] RECEIVED: ( 01 08 00 04 00 15 02 98 40 3C )
[2017-03-04 09:25:20.915] [D] [zway] SENT ACK
[2017-03-04 09:25:20.915] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:20.918] [I] [zway] Node 21:0 CC Security: sending Nonce Report
[2017-03-04 09:25:20.918] [I] [zway] Adding job: Nonce Report
[2017-03-04 09:25:20.918] [D] [zway] SENDING (cb 0x70): ( 01 11 00 13 15 0A 98 80 27 81 FA 84 BC C4 6C 21 05 70 62 )
[2017-03-04 09:25:20.926] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:20.926] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:20.926] [D] [zway] SENT ACK
[2017-03-04 09:25:20.926] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:21.078] [D] [zway] RECEIVED: ( 01 07 00 13 70 00 00 10 8B )
[2017-03-04 09:25:21.078] [D] [zway] SENT ACK
[2017-03-04 09:25:21.078] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-04 09:25:21.078] [D] [zway] SendData Response with callback 0x70 received: received by recipient
[2017-03-04 09:25:21.078] [D] [zway] SETDATA devices.21.data.lastSend = 55696810 (0x0351ddaa)
[2017-03-04 09:25:21.078] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-04 09:25:21.078] [I] [zway] Removing job: Nonce Report
[2017-03-04 09:25:21.179] [D] [zway] RECEIVED: ( 01 25 00 04 00 15 1F 98 81 A6 15 45 6B A1 86 B0 2D AC 38 48 1F E4 D3 18 6F 0B 1A EC 4B 27 DF 2E 8E 0C D0 7C D1 82 74 )
[2017-03-04 09:25:21.179] [D] [zway] SENT ACK
[2017-03-04 09:25:21.179] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:21.179] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:25:21.181] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-04 09:25:21.181] [I] [zway] Node 21:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 06 06 01 00 00 ]
[2017-03-04 09:25:21.181] [D] [zway] SETDATA devices.21.instances.0.commandClasses.113.data.6.eventParameters = byte[1]
[2017-03-04 09:25:21.181] [D] [zway]   ( 00 )
[2017-03-04 09:25:21.181] [D] [zway] SETDATA devices.21.instances.0.commandClasses.113.data.6.event = 6 (0x00000006)
[2017-03-04 09:25:21.184] [D] [zway] SETDATA devices.21.instances.0.commandClasses.113.data.6.eventString = "Keypad Lock Open Operation"
[2017-03-04 09:25:21.184] [D] [zway] SETDATA devices.21.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2017-03-04 09:25:21.184] [D] [zway] SETDATA devices.21.instances.0.commandClasses.113.data.6 = Empty
[2017-03-04 09:25:21.912] [D] [zway] RECEIVED: ( 01 08 00 04 00 15 02 98 40 3C )
[2017-03-04 09:25:21.912] [D] [zway] SENT ACK
[2017-03-04 09:25:21.912] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:21.925] [I] [zway] Node 21:0 CC Security: sending Nonce Report
[2017-03-04 09:25:21.926] [I] [zway] Adding job: Nonce Report
[2017-03-04 09:25:21.926] [D] [zway] SENDING (cb 0x71): ( 01 11 00 13 15 0A 98 80 BE 5F A8 0E 87 51 26 11 05 71 28 )
[2017-03-04 09:25:21.928] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:21.932] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:21.932] [D] [zway] SENT ACK
[2017-03-04 09:25:21.932] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:22.068] [D] [zway] RECEIVED: ( 01 07 00 13 71 00 00 0E 94 )
[2017-03-04 09:25:22.068] [D] [zway] SENT ACK
[2017-03-04 09:25:22.069] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-04 09:25:22.069] [D] [zway] SendData Response with callback 0x71 received: received by recipient
[2017-03-04 09:25:22.069] [D] [zway] SETDATA devices.21.data.lastSend = 55696907 (0x0351de0b)
[2017-03-04 09:25:22.069] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-04 09:25:22.069] [I] [zway] Removing job: Nonce Report
[2017-03-04 09:25:22.164] [D] [zway] RECEIVED: ( 01 21 00 04 00 15 1B 98 81 E0 50 D5 A1 6F B9 BB C9 8C 69 CA DE 28 57 25 38 BE CE 11 1D 15 C7 10 A0 22 02 )
[2017-03-04 09:25:22.164] [D] [zway] SENT ACK
[2017-03-04 09:25:22.164] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:22.164] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:25:22.171] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-04 09:25:22.171] [I] [zway] Node 21:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 03 fe fe ]
[2017-03-04 09:25:22.171] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-03-04 09:25:22.172] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-04 09:25:22.172] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-04 09:25:22.172] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.condition = 3 (0x00000003)
[2017-03-04 09:25:22.172] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-04 09:25:22.172] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-03-04 09:25:23.422] [D] [zway] RECEIVED: ( 01 08 00 04 00 15 02 98 40 3C )
[2017-03-04 09:25:23.423] [D] [zway] SENT ACK
[2017-03-04 09:25:23.423] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:23.430] [I] [zway] Node 21:0 CC Security: sending Nonce Report
[2017-03-04 09:25:23.430] [I] [zway] Adding job: Nonce Report
[2017-03-04 09:25:23.430] [D] [zway] SENDING (cb 0x72): ( 01 11 00 13 15 0A 98 80 65 E8 89 7D 59 1D F7 6A 05 72 2D )
[2017-03-04 09:25:23.433] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:23.436] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:23.437] [D] [zway] SENT ACK
[2017-03-04 09:25:23.437] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:23.594] [D] [zway] RECEIVED: ( 01 07 00 13 72 00 00 0F 96 )
[2017-03-04 09:25:23.594] [D] [zway] SENT ACK
[2017-03-04 09:25:23.594] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-04 09:25:23.595] [D] [zway] SendData Response with callback 0x72 received: received by recipient
[2017-03-04 09:25:23.595] [D] [zway] SETDATA devices.21.data.lastSend = 55697056 (0x0351dea0)
[2017-03-04 09:25:23.595] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-04 09:25:23.595] [I] [zway] Removing job: Nonce Report
[2017-03-04 09:25:23.685] [D] [zway] RECEIVED: ( 01 21 00 04 00 15 1B 98 81 1A 72 88 05 5E 03 A6 F9 DD 1C 85 1F 20 9A E3 D4 65 08 2B D0 83 3B E9 C6 0E F3 )
[2017-03-04 09:25:23.685] [D] [zway] SENT ACK
[2017-03-04 09:25:23.685] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:23.686] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:25:23.689] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-04 09:25:23.689] [I] [zway] Node 21:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 02 fe fe ]
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.condition = 2 (0x00000002)
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-04 09:25:23.690] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-03-04 09:25:24.940] [D] [zway] RECEIVED: ( 01 08 00 04 00 15 02 98 40 3C )
[2017-03-04 09:25:24.941] [D] [zway] SENT ACK
[2017-03-04 09:25:24.941] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:24.952] [I] [zway] Node 21:0 CC Security: sending Nonce Report
[2017-03-04 09:25:24.953] [I] [zway] Adding job: Nonce Report
[2017-03-04 09:25:24.953] [D] [zway] SENDING (cb 0x73): ( 01 11 00 13 15 0A 98 80 A9 8E AF 8E 58 FC 95 BD 05 73 06 )
[2017-03-04 09:25:24.955] [D] [zway] RECEIVED ACK
[2017-03-04 09:25:24.959] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-04 09:25:24.959] [D] [zway] SENT ACK
[2017-03-04 09:25:24.959] [D] [zway] Delivered to Z-Wave stack
[2017-03-04 09:25:25.105] [D] [zway] RECEIVED: ( 01 07 00 13 73 00 00 0E 96 )
[2017-03-04 09:25:25.106] [D] [zway] SENT ACK
[2017-03-04 09:25:25.109] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-04 09:25:25.110] [D] [zway] SendData Response with callback 0x73 received: received by recipient
[2017-03-04 09:25:25.110] [D] [zway] SETDATA devices.21.data.lastSend = 55697204 (0x0351df34)
[2017-03-04 09:25:25.110] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-04 09:25:25.110] [I] [zway] Removing job: Nonce Report
[2017-03-04 09:25:25.200] [D] [zway] RECEIVED: ( 01 21 00 04 00 15 1B 98 81 19 52 BF FA 45 8B 38 F3 93 95 30 59 FE 98 DF A7 A9 6F 46 90 0C 38 9D E8 AF 49 )
[2017-03-04 09:25:25.200] [D] [zway] SENT ACK
[2017-03-04 09:25:25.201] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2017-03-04 09:25:25.201] [I] [zway] Node 21:0 CC Security: Received a secure message
[2017-03-04 09:25:25.206] [D] [zway] SETDATA devices.21.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-04 09:25:25.207] [I] [zway] Node 21:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 03 fe fe ]
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.condition = 3 (0x00000003)
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-04 09:25:25.207] [D] [zway] SETDATA devices.21.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
Either way the lock opens, but the status given by Z-Way, and the value of "level" that the api returns, is always closed. Does anyone see from the logs what could be the problem here?
Re: ID Lock 101 no status update
This should change device state to Open. Isn't it?
Provo
Post by Provo »
No, the status is always closed, no matter the actual state of the lock, and no matter how I opened it.
EDIT: In case I wasn't clear, the lock itself does unlock and behave like expected. It's just the status of the vDev in the UI and API that doesn't update. Operating the lock causes no no mention of it under the Events page either.
Provo
Post by Provo »
This works again after upgrade to 2.3.1.
