Is this UZB1 stick damaged?
ekkzk5f
Post by ekkzk5f »
I have a Z-Wave.me UZB1 stick in use which is not working properly anymore with a Open-ZWave library based application. Other UZB1 sticks are working fine with the same software, so it is for sure no problem of the application.
This one stick receives after start of the application only 5x notifications of the Type_Notification for the node 255 (which was never included, probably it is invalid number).
No more notifications, no bootstrap of the network - silence!
When looking to the OZW_Log.txt:
Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
So it looks like the Home ID is now 0x00000000, before it was 0xf2de4e64
I've already tried SoftReset, restart application, reboot system, remove or restore of the zwcfg*.xml file... nothing helps.
Is this a hardware problem of the UZB1 stick?
Re: Is this UZB1 stick damaged?
Please check it's home ID. Looks like a known issue (solution here: http://razberry.z-wave.me/index.php?id=29 - search for 5555555)
ekkzk5f
Post by ekkzk5f »
Thanks for your feedback,
the software tries it with home ID 0x00000000 which is for sure invalid. Before It worked with 0xf2de4e64 on the same UZB1 (I've updated my fist posting with logfile details).
So it looks like none of the hints on the mentioned RaZberry support page helps for my UZB1 stick
Well, you can try the one from 55555555, but it will erase all your data on the dongle (looks it is already lost). If it will not help, looks the EEPROM on the UZB1 is damaged. Usually this is due to ESD or a spike in powering voltage.
