UZB1 using SUC mode
ekkzk5f
UZB1 using SUC mode
Post by ekkzk5f »
Hi seniors,
is it possible to include an UZB1 stick as Static Update Controller (SUC), is this mode supported by UZB1 hardware?
Achim
Re: UZB1 using SUC mode
Sure, it is. You primary should assign SUC role to UZB1
ekkzk5f
Post by ekkzk5f »
Hmmm,
I've tried to enable it in OpenZWave options.xml file by adding
<Option name="EnableSIS" value="true" />
Which result for a UZB1 in a OZW_Log:
Received reply to GET_SUC_NODE_ID.  Node ID = 0
Controller Does not Support SUC - Cannot Setup Controller as SUC Node
It does not support EnableSUC, since it is on by default (according to Z-Wave Plus specs). It can become SIS with no problems. Please check it with OZW support. With Z-Way s/w it works in SUC and SIS mode.
ekkzk5f
Post by ekkzk5f »
OK, so it looks like the OZW ordinary (non Plus) handling of UZB1 is the problem, see my other topic https://forum.z-wave.me/viewtopic.php?f=3419&t=24704
