Problem with one device after upgrading to 2.3.0/2.3.1
bjoern812
Post by bjoern812 »
I have some problem with my Zipato Siren (Philio PSE02 brand). I think it started with my update from 2.2.4 to 2.3.0.
After updating to 2.3.0 everything works as expected. But after few weeks running 2.3.0 the siren stops working.
I could not start the siren with the vDev. If I look at the queue, if seems that the packets were not sending or the device
is not responding.
After I have reset the siren, it starts working. But than, only after a few days of working, it stops working. So next try, I
exclude and include the siren. It starts working. A few days more than last. But than, the siren stops working again.
Thats what the queue is showing:
0			S			-	-	-	0.20	34	Association Remove		22 4 85 4 1 1 25
0			S			-	-	-	0.20	34	Association Get		22 3 85 2 1 25
0			S			-	-	-	0.20	34	Alarm		22 a 71 5 0 0 0 0 a 5 0 0 25
0			S			-	-	-	0.20	34	SensorBinary Get v2		22 3 30 2 1 25
0			S			-	-	-	0.20	34	SensorBinary Get v2		22 3 30 2 8 25
0			S			-	-	-	0.20	34	Alarm Get (v3)		22 5 71 4 0 7 0 25
1					D	+	+	+	9.35	34	Nonce Get	Delivered	22 2 98 40 25
1					D	+	+	+	19.53	34	Nonce Get	Delivered	22 2 98 40 25
I look at the log file and grep a bit for the device node (34). I found that entry after it stops working:
[2017-05-25 14:20:03.499] [I] [zway] Node 34:0 CC Security: sending Nonce Report
[2017-05-25 14:20:03.642] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:20:03.642] [I] [zway] Node 34:0 CC Security: passing decrypted packet to application level: [ 30 03 00 08 ]
[2017-05-25 14:20:03.704] [I] [zway] Node 34:0 CC Security: received Nonce Report
[2017-05-25 14:20:03.704] [I] [zway] Node 34:0 CC Security: Sending a secure message
[2017-05-25 14:20:03.705] [I] [zway] Node 34:0 CC Security: sending encrypted packet: Alarm Get (v3)
[2017-05-25 14:20:03.868] [I] [zway] Node 34:0 CC Security: sending Nonce Report
[2017-05-25 14:20:03.970] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:20:03.970] [I] [zway] Node 34:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 fe 00 ]
[2017-05-25 14:30:00.883] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:30:01.323] [I] [zway] Node 34:0 CC Security: received Nonce Report
[2017-05-25 14:30:01.323] [I] [zway] Node 34:0 CC Security: Sending a secure message
[2017-05-25 14:30:01.324] [I] [zway] Node 34:0 CC Security: sending encrypted packet: Alarm Get (v3)
[2017-05-25 14:30:01.437] [I] [zway] Node 34:0 CC Security: sending Nonce Report
[2017-05-25 14:30:01.629] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:30:01.630] [I] [zway] Node 34:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 fe 00 ]
[2017-05-25 14:40:00.070] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:01.723] [I] [zway] Node 34:0 CC Security: received Nonce Report
[2017-05-25 14:40:01.723] [I] [zway] Node 34:0 CC Security: Sending a secure message
[2017-05-25 14:40:01.723] [I] [zway] Node 34:0 CC Security: sending encrypted packet: SensorBinary Get v2
[2017-05-25 14:40:01.725] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:01.949] [I] [zway] Node 34:0 CC Security: sending Nonce Report
[2017-05-25 14:40:02.164] [I] [zway] Node 34:0 CC Security: sending Nonce Report
[2017-05-25 14:40:03.317] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:40:03.318] [I] [zway] Node 34:0 CC Security: passing decrypted packet to application level: [ 30 03 00 01 ]
[2017-05-25 14:40:03.889] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:40:03.889] [W] [zway] Node 34:0 CC Security: can not decrypt packet due to nonce lookup problem
[2017-05-25 14:40:04.675] [I] [zway] Node 34:0 CC Security: Received a secure message
[2017-05-25 14:40:04.675] [W] [zway] Node 34:0 CC Security: can not decrypt packet due to nonce lookup problem
[2017-05-25 14:40:16.106] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:26.383] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:36.641] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:46.898] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:40:57.155] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:07.422] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:17.690] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:27.946] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:38.201] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:48.465] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:41:58.725] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:42:08.993] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:42:19.255] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:42:29.517] [I] [zway] Node 34:0 CC Security: sending Nonce Get
So, has it something to do with the "can not decrypt packet due to nonce lookup problem"?
And can it be hardware failure or a software problem from z-way?
Z-Way-Version: 2.3.1 (razberry)
SDK Version: 6.51.03
Serial API Version: 05.00
Any help would be appreciate.
Bjoern.
Re: Problem with one device after upgrading to 2.3.0/2.3.1
looks like device is not answering with a Nonce Reply anymore. And enable debug logging
bjoern812
Post by bjoern812 »
Dear PoltoS,
thank you for your reply.
I think, I have already enabled the debug logging, because my config.xml shows:
<log-level>0</log-level>
I have just grepped the output from log for only "node 34".
Maybe, another grep helped more (grep for devices.34 and node 34):
[2017-05-25 14:30:00.884] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:30:00.884] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31478518 (0x01e052f6)
[2017-05-25 14:30:01.262] [D] [zway] SETDATA devices.34.data.lastSend = 31478556 (0x01e0531c)
[2017-05-25 14:30:01.263] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:30:01.263] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31478556 (0x01e0531c)
[2017-05-25 14:30:01.323] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:30:01.323] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonce = **********
[2017-05-25 14:30:01.324] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.toFollow = False
[2017-05-25 14:30:01.324] [D] [zway] SETDATA devices.34.data.lastNonceGet = Empty
[2017-05-25 14:30:01.425] [D] [zway] SETDATA devices.34.data.lastSend = 31478572 (0x01e0532c)
[2017-05-25 14:30:01.435] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:30:01.609] [D] [zway] SETDATA devices.34.data.lastSend = 31478590 (0x01e0533e)
[2017-05-25 14:30:01.629] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:30:01.630] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.firstPart = **********
[2017-05-25 14:30:01.630] [D] [zway] SETDATA devices.34.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2017-05-25 14:30:01.631] [D] [zway] SETDATA devices.34.instances.0.commandClasses.113.data.7.event = 254 (0x000000fe)
[2017-05-25 14:30:01.633] [D] [zway] SETDATA devices.34.instances.0.commandClasses.113.data.7.eventString = "unknown"
[2017-05-25 14:30:01.633] [D] [zway] SETDATA devices.34.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2017-05-25 14:30:01.633] [D] [zway] SETDATA devices.34.instances.0.commandClasses.113.data.7 = Empty
[2017-05-25 14:40:00.070] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:00.071] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31537309 (0x01e1389d)
[2017-05-25 14:40:01.713] [D] [zway] SETDATA devices.34.data.lastSend = 31537471 (0x01e1393f)
[2017-05-25 14:40:01.713] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:01.713] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31537471 (0x01e1393f)
[2017-05-25 14:40:01.722] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:01.723] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonce = **********
[2017-05-25 14:40:01.724] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.toFollow = False
[2017-05-25 14:40:01.724] [D] [zway] SETDATA devices.34.data.lastNonceGet = Empty
[2017-05-25 14:40:01.725] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:01.725] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31537472 (0x01e13940)
[2017-05-25 14:40:01.938] [D] [zway] SETDATA devices.34.data.lastSend = 31537493 (0x01e13955)
[2017-05-25 14:40:01.948] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:02.163] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:02.959] [D] [zway] SETDATA devices.34.data.lastSend = 31537593 (0x01e139b9)
[2017-05-25 14:40:03.316] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:03.317] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.firstPart = **********
[2017-05-25 14:40:03.318] [D] [zway] SETDATA devices.34.instances.0.commandClasses.48.data.1.level = False
[2017-05-25 14:40:03.318] [D] [zway] SETDATA devices.34.instances.0.commandClasses.48.data.1 = Empty
[2017-05-25 14:40:03.888] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:04.674] [D] [zway] SETDATA devices.34.data.lastReceived = 0 (0x00000000)
[2017-05-25 14:40:05.737] [D] [zway] SETDATA devices.34.data.lastSend = 31537865 (0x01e13ac9)
[2017-05-25 14:40:05.849] [D] [zway] SETDATA devices.34.data.lastSend = 31537876 (0x01e13ad4)
[2017-05-25 14:40:05.849] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:05.849] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31537876 (0x01e13ad4)
[2017-05-25 14:40:16.106] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:16.107] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31538877 (0x01e13ebd)
[2017-05-25 14:40:16.138] [D] [zway] SETDATA devices.34.data.lastSend = 31538881 (0x01e13ec1)
[2017-05-25 14:40:16.138] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:16.139] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31538881 (0x01e13ec1)
[2017-05-25 14:40:26.383] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:26.383] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31539882 (0x01e142aa)
[2017-05-25 14:40:26.415] [D] [zway] SETDATA devices.34.data.lastSend = 31539886 (0x01e142ae)
[2017-05-25 14:40:26.415] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:26.415] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31539886 (0x01e142ae)
[2017-05-25 14:40:36.641] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:36.641] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31540887 (0x01e14697)
[2017-05-25 14:40:36.673] [D] [zway] SETDATA devices.34.data.lastSend = 31540891 (0x01e1469b)
[2017-05-25 14:40:36.673] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:36.673] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31540891 (0x01e1469b)
[2017-05-25 14:40:46.898] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:46.898] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31541892 (0x01e14a84)
[2017-05-25 14:40:46.930] [D] [zway] SETDATA devices.34.data.lastSend = 31541896 (0x01e14a88)
[2017-05-25 14:40:46.930] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:46.930] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31541896 (0x01e14a88)
[2017-05-25 14:40:57.156] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:57.156] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31542897 (0x01e14e71)
[2017-05-25 14:40:57.196] [D] [zway] SETDATA devices.34.data.lastSend = 31542902 (0x01e14e76)
[2017-05-25 14:40:57.197] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:40:57.197] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31542902 (0x01e14e76)
[2017-05-25 14:41:07.423] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:07.423] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31543903 (0x01e1525f)
[2017-05-25 14:41:07.464] [D] [zway] SETDATA devices.34.data.lastSend = 31543908 (0x01e15264)
[2017-05-25 14:41:07.464] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:07.464] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31543908 (0x01e15264)
[2017-05-25 14:41:17.690] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:17.691] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31544909 (0x01e1564d)
[2017-05-25 14:41:17.722] [D] [zway] SETDATA devices.34.data.lastSend = 31544913 (0x01e15651)
[2017-05-25 14:41:17.723] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:17.723] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31544913 (0x01e15651)
[2017-05-25 14:41:27.946] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:27.946] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31545914 (0x01e15a3a)
[2017-05-25 14:41:27.978] [D] [zway] SETDATA devices.34.data.lastSend = 31545918 (0x01e15a3e)
[2017-05-25 14:41:27.978] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:27.978] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31545918 (0x01e15a3e)
[2017-05-25 14:41:38.202] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:38.202] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31546919 (0x01e15e27)
[2017-05-25 14:41:38.234] [D] [zway] SETDATA devices.34.data.lastSend = 31546923 (0x01e15e2b)
[2017-05-25 14:41:38.234] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:38.234] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31546923 (0x01e15e2b)
[2017-05-25 14:41:48.465] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:48.465] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31547924 (0x01e16214)
[2017-05-25 14:41:48.497] [D] [zway] SETDATA devices.34.data.lastSend = 31547928 (0x01e16218)
[2017-05-25 14:41:48.497] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:48.497] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31547928 (0x01e16218)
[2017-05-25 14:41:58.725] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:58.726] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31548929 (0x01e16601)
[2017-05-25 14:41:58.757] [D] [zway] SETDATA devices.34.data.lastSend = 31548933 (0x01e16605)
[2017-05-25 14:41:58.757] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:41:58.758] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31548933 (0x01e16605)
[2017-05-25 14:42:08.993] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:08.993] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31549934 (0x01e169ee)
[2017-05-25 14:42:09.025] [D] [zway] SETDATA devices.34.data.lastSend = 31549938 (0x01e169f2)
[2017-05-25 14:42:09.025] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:09.025] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31549938 (0x01e169f2)
[2017-05-25 14:42:19.255] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:19.255] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31550939 (0x01e16ddb)
[2017-05-25 14:42:19.287] [D] [zway] SETDATA devices.34.data.lastSend = 31550943 (0x01e16ddf)
[2017-05-25 14:42:19.287] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:19.287] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31550943 (0x01e16ddf)
[2017-05-25 14:42:29.517] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:29.517] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31551944 (0x01e171c8)
[2017-05-25 14:42:29.549] [D] [zway] SETDATA devices.34.data.lastSend = 31551948 (0x01e171cc)
[2017-05-25 14:42:29.549] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:29.549] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31551948 (0x01e171cc)
[2017-05-25 14:42:39.774] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:42:39.774] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:39.775] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31552949 (0x01e175b5)
[2017-05-25 14:42:39.806] [D] [zway] SETDATA devices.34.data.lastSend = 31552953 (0x01e175b9)
[2017-05-25 14:42:39.807] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:39.807] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31552953 (0x01e175b9)
[2017-05-25 14:42:50.031] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:42:50.031] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:50.032] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31553954 (0x01e179a2)
[2017-05-25 14:42:50.063] [D] [zway] SETDATA devices.34.data.lastSend = 31553958 (0x01e179a6)
[2017-05-25 14:42:50.064] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:42:50.064] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31553958 (0x01e179a6)
[2017-05-25 14:43:00.288] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:00.289] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:00.289] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31554959 (0x01e17d8f)
[2017-05-25 14:43:00.329] [D] [zway] SETDATA devices.34.data.lastSend = 31554964 (0x01e17d94)
[2017-05-25 14:43:00.329] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:00.330] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31554964 (0x01e17d94)
[2017-05-25 14:43:10.553] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:10.553] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:10.553] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31555965 (0x01e1817d)
[2017-05-25 14:43:10.585] [D] [zway] SETDATA devices.34.data.lastSend = 31555969 (0x01e18181)
[2017-05-25 14:43:10.585] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:10.586] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31555969 (0x01e18181)
[2017-05-25 14:43:20.808] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:20.809] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:20.809] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31556970 (0x01e1856a)
[2017-05-25 14:43:20.849] [D] [zway] SETDATA devices.34.data.lastSend = 31556975 (0x01e1856f)
[2017-05-25 14:43:20.850] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:20.850] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31556975 (0x01e1856f)
[2017-05-25 14:43:31.102] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:31.102] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:31.102] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31557976 (0x01e18958)
[2017-05-25 14:43:31.134] [D] [zway] SETDATA devices.34.data.lastSend = 31557980 (0x01e1895c)
[2017-05-25 14:43:31.134] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:31.135] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31557980 (0x01e1895c)
[2017-05-25 14:43:41.386] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:41.387] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:41.387] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31558981 (0x01e18d45)
[2017-05-25 14:43:41.428] [D] [zway] SETDATA devices.34.data.lastSend = 31558986 (0x01e18d4a)
[2017-05-25 14:43:41.428] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:41.428] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31558986 (0x01e18d4a)
[2017-05-25 14:43:51.681] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:43:51.682] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:51.682] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31559987 (0x01e19133)
[2017-05-25 14:43:51.714] [D] [zway] SETDATA devices.34.data.lastSend = 31559991 (0x01e19137)
[2017-05-25 14:43:51.714] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:43:51.714] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31559991 (0x01e19137)
[2017-05-25 14:44:01.966] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:01.967] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:01.967] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31560992 (0x01e19520)
[2017-05-25 14:44:01.999] [D] [zway] SETDATA devices.34.data.lastSend = 31560996 (0x01e19524)
[2017-05-25 14:44:01.999] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:01.999] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31560996 (0x01e19524)
[2017-05-25 14:44:12.254] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:12.254] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:12.255] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31561997 (0x01e1990d)
[2017-05-25 14:44:12.287] [D] [zway] SETDATA devices.34.data.lastSend = 31562001 (0x01e19911)
[2017-05-25 14:44:12.287] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:12.287] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31562001 (0x01e19911)
[2017-05-25 14:44:22.537] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:22.537] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:22.538] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31563002 (0x01e19cfa)
[2017-05-25 14:44:22.579] [D] [zway] SETDATA devices.34.data.lastSend = 31563007 (0x01e19cff)
[2017-05-25 14:44:22.579] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:22.579] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31563007 (0x01e19cff)
[2017-05-25 14:44:32.812] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:32.812] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:32.813] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31564008 (0x01e1a0e8)
[2017-05-25 14:44:32.844] [D] [zway] SETDATA devices.34.data.lastSend = 31564012 (0x01e1a0ec)
[2017-05-25 14:44:32.845] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:32.845] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31564012 (0x01e1a0ec)
[2017-05-25 14:44:43.099] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:43.099] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:43.100] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31565013 (0x01e1a4d5)
[2017-05-25 14:44:43.131] [D] [zway] SETDATA devices.34.data.lastSend = 31565017 (0x01e1a4d9)
[2017-05-25 14:44:43.132] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:43.132] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31565017 (0x01e1a4d9)
[2017-05-25 14:44:53.383] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:44:53.383] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:53.384] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31566018 (0x01e1a8c2)
[2017-05-25 14:44:53.416] [D] [zway] SETDATA devices.34.data.lastSend = 31566022 (0x01e1a8c6)
[2017-05-25 14:44:53.417] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:44:53.417] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31566022 (0x01e1a8c6)
[2017-05-25 14:45:03.668] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:03.669] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:03.669] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31567023 (0x01e1acaf)
[2017-05-25 14:45:03.701] [D] [zway] SETDATA devices.34.data.lastSend = 31567027 (0x01e1acb3)
[2017-05-25 14:45:03.701] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:03.701] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31567027 (0x01e1acb3)
[2017-05-25 14:45:13.953] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:13.953] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:13.953] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31568028 (0x01e1b09c)
[2017-05-25 14:45:13.985] [D] [zway] SETDATA devices.34.data.lastSend = 31568032 (0x01e1b0a0)
[2017-05-25 14:45:13.985] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:13.985] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31568032 (0x01e1b0a0)
[2017-05-25 14:45:24.221] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:24.222] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:24.222] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31569033 (0x01e1b489)
[2017-05-25 14:45:24.263] [D] [zway] SETDATA devices.34.data.lastSend = 31569038 (0x01e1b48e)
[2017-05-25 14:45:24.263] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:24.263] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31569038 (0x01e1b48e)
[2017-05-25 14:45:34.493] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:34.494] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:34.494] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31570039 (0x01e1b877)
[2017-05-25 14:45:34.525] [D] [zway] SETDATA devices.34.data.lastSend = 31570043 (0x01e1b87b)
[2017-05-25 14:45:34.526] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:34.526] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31570043 (0x01e1b87b)
[2017-05-25 14:45:44.756] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:44.756] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:44.756] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31571044 (0x01e1bc64)
[2017-05-25 14:45:44.788] [D] [zway] SETDATA devices.34.data.lastSend = 31571048 (0x01e1bc68)
[2017-05-25 14:45:44.788] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:44.788] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31571048 (0x01e1bc68)
[2017-05-25 14:45:55.017] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:45:55.017] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:55.018] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31572049 (0x01e1c051)
[2017-05-25 14:45:55.049] [D] [zway] SETDATA devices.34.data.lastSend = 31572053 (0x01e1c055)
[2017-05-25 14:45:55.049] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:45:55.049] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31572053 (0x01e1c055)
[2017-05-25 14:46:05.280] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:05.280] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:05.281] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31573054 (0x01e1c43e)
[2017-05-25 14:46:05.313] [D] [zway] SETDATA devices.34.data.lastSend = 31573058 (0x01e1c442)
[2017-05-25 14:46:05.313] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:05.313] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31573058 (0x01e1c442)
[2017-05-25 14:46:15.548] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:15.548] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:15.548] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31574059 (0x01e1c82b)
[2017-05-25 14:46:15.580] [D] [zway] SETDATA devices.34.data.lastSend = 31574063 (0x01e1c82f)
[2017-05-25 14:46:15.580] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:15.580] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31574063 (0x01e1c82f)
[2017-05-25 14:46:25.811] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:25.811] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:25.812] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31575064 (0x01e1cc18)
[2017-05-25 14:46:25.843] [D] [zway] SETDATA devices.34.data.lastSend = 31575068 (0x01e1cc1c)
[2017-05-25 14:46:25.843] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:25.843] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31575068 (0x01e1cc1c)
[2017-05-25 14:46:36.072] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:36.072] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:36.072] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31576069 (0x01e1d005)
[2017-05-25 14:46:36.104] [D] [zway] SETDATA devices.34.data.lastSend = 31576073 (0x01e1d009)
[2017-05-25 14:46:36.104] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:36.104] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31576073 (0x01e1d009)
[2017-05-25 14:46:46.331] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:46.331] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:46.332] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31577074 (0x01e1d3f2)
[2017-05-25 14:46:46.364] [D] [zway] SETDATA devices.34.data.lastSend = 31577078 (0x01e1d3f6)
[2017-05-25 14:46:46.364] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:46.364] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31577078 (0x01e1d3f6)
[2017-05-25 14:46:56.592] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:46:56.593] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:56.593] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31578079 (0x01e1d7df)
[2017-05-25 14:46:56.625] [D] [zway] SETDATA devices.34.data.lastSend = 31578083 (0x01e1d7e3)
[2017-05-25 14:46:56.625] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:46:56.625] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31578083 (0x01e1d7e3)
[2017-05-25 14:47:06.855] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:06.855] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:06.855] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31579084 (0x01e1dbcc)
[2017-05-25 14:47:06.887] [D] [zway] SETDATA devices.34.data.lastSend = 31579088 (0x01e1dbd0)
[2017-05-25 14:47:06.887] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:06.887] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31579088 (0x01e1dbd0)
[2017-05-25 14:47:17.118] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:17.119] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:17.119] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31580089 (0x01e1dfb9)
[2017-05-25 14:47:17.151] [D] [zway] SETDATA devices.34.data.lastSend = 31580093 (0x01e1dfbd)
[2017-05-25 14:47:17.151] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:17.151] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31580093 (0x01e1dfbd)
[2017-05-25 14:47:27.381] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:27.381] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:27.381] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31581094 (0x01e1e3a6)
[2017-05-25 14:47:27.413] [D] [zway] SETDATA devices.34.data.lastSend = 31581098 (0x01e1e3aa)
[2017-05-25 14:47:27.413] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:27.413] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31581098 (0x01e1e3aa)
[2017-05-25 14:47:37.641] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:37.641] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:37.641] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31582099 (0x01e1e793)
[2017-05-25 14:47:37.673] [D] [zway] SETDATA devices.34.data.lastSend = 31582103 (0x01e1e797)
[2017-05-25 14:47:37.673] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:37.673] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31582103 (0x01e1e797)
[2017-05-25 14:47:47.906] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:47.907] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:47.907] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31583104 (0x01e1eb80)
[2017-05-25 14:47:47.939] [D] [zway] SETDATA devices.34.data.lastSend = 31583108 (0x01e1eb84)
[2017-05-25 14:47:47.939] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:47.939] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31583108 (0x01e1eb84)
[2017-05-25 14:47:58.164] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:47:58.164] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:58.164] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31584109 (0x01e1ef6d)
[2017-05-25 14:47:58.196] [D] [zway] SETDATA devices.34.data.lastSend = 31584113 (0x01e1ef71)
[2017-05-25 14:47:58.196] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:47:58.196] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31584113 (0x01e1ef71)
[2017-05-25 14:48:08.421] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:08.422] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:08.422] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31585114 (0x01e1f35a)
[2017-05-25 14:48:08.454] [D] [zway] SETDATA devices.34.data.lastSend = 31585118 (0x01e1f35e)
[2017-05-25 14:48:08.454] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:08.454] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31585118 (0x01e1f35e)
[2017-05-25 14:48:18.707] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:18.707] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:18.707] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31586119 (0x01e1f747)
[2017-05-25 14:48:18.739] [D] [zway] SETDATA devices.34.data.lastSend = 31586123 (0x01e1f74b)
[2017-05-25 14:48:18.739] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:18.740] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31586123 (0x01e1f74b)
[2017-05-25 14:48:28.994] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:28.994] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:28.995] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31587124 (0x01e1fb34)
[2017-05-25 14:48:29.027] [D] [zway] SETDATA devices.34.data.lastSend = 31587128 (0x01e1fb38)
[2017-05-25 14:48:29.027] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:29.027] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31587128 (0x01e1fb38)
[2017-05-25 14:48:39.254] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:39.254] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:39.255] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31588129 (0x01e1ff21)
[2017-05-25 14:48:39.287] [D] [zway] SETDATA devices.34.data.lastSend = 31588133 (0x01e1ff25)
[2017-05-25 14:48:39.287] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:39.287] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31588133 (0x01e1ff25)
[2017-05-25 14:48:49.538] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:49.538] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:49.538] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31589134 (0x01e2030e)
[2017-05-25 14:48:49.570] [D] [zway] SETDATA devices.34.data.lastSend = 31589138 (0x01e20312)
[2017-05-25 14:48:49.570] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:49.571] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31589138 (0x01e20312)
[2017-05-25 14:48:59.813] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:48:59.814] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:59.814] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31590139 (0x01e206fb)
[2017-05-25 14:48:59.845] [D] [zway] SETDATA devices.34.data.lastSend = 31590143 (0x01e206ff)
[2017-05-25 14:48:59.846] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:48:59.846] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31590143 (0x01e206ff)
[2017-05-25 14:49:10.075] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:49:10.075] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:10.075] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31591144 (0x01e20ae8)
[2017-05-25 14:49:10.107] [D] [zway] SETDATA devices.34.data.lastSend = 31591148 (0x01e20aec)
[2017-05-25 14:49:10.107] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:10.107] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31591148 (0x01e20aec)
[2017-05-25 14:49:20.337] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:49:20.337] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:20.338] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31592149 (0x01e20ed5)
[2017-05-25 14:49:20.369] [D] [zway] SETDATA devices.34.data.lastSend = 31592153 (0x01e20ed9)
[2017-05-25 14:49:20.370] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:20.370] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31592153 (0x01e20ed9)
[2017-05-25 14:49:30.598] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:49:30.598] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:30.598] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31593154 (0x01e212c2)
[2017-05-25 14:49:30.630] [D] [zway] SETDATA devices.34.data.lastSend = 31593158 (0x01e212c6)
[2017-05-25 14:49:30.630] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:30.630] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31593158 (0x01e212c6)
[2017-05-25 14:49:40.889] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:49:40.889] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:40.890] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31594159 (0x01e216af)
[2017-05-25 14:49:40.921] [D] [zway] SETDATA devices.34.data.lastSend = 31594163 (0x01e216b3)
[2017-05-25 14:49:40.922] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:40.922] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31594163 (0x01e216b3)
[2017-05-25 14:49:51.160] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:49:51.160] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:51.160] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31595164 (0x01e21a9c)
[2017-05-25 14:49:51.192] [D] [zway] SETDATA devices.34.data.lastSend = 31595168 (0x01e21aa0)
[2017-05-25 14:49:51.192] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:49:51.192] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31595168 (0x01e21aa0)
[2017-05-25 14:50:01.938] [I] [zway] Node 34:0 CC Security: sending Nonce Get
[2017-05-25 14:50:01.938] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:50:01.938] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31596219 (0x01e21ebb)
[2017-05-25 14:50:06.177] [D] [zway] SETDATA devices.34.data.lastSend = 31596634 (0x01e2205a)
[2017-05-25 14:50:06.178] [D] [zway] SETDATA devices.34.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-05-25 14:50:06.178] [D] [zway] SETDATA devices.34.data.lastNonceGet = 31596634 (0x01e2205a)
[2017-05-25 14:50:16.443] [I] [zway] Node 34:0 CC Security: sending Nonce Get
Can this be a faulty hardware device? Or is it possible that the problems is on Z-Way?
Thank you very much!
Bjoern
Please don't grep. There are a lot of SEND/RECEIVE information in the log. It will help to understand whom to blame. But from the log above the device stopped answering Nonce Get, so it looks like it forgot it's secure inclusion.
enbemokel
Post by enbemokel »
Thats interesting. I use the D-Link DCH-Z510 and have the same symptom in my network.
Have to restart the Z510 once a week then everything is fine...... 2.3.4 Version.
bjoern812
Post by bjoern812 »
@PoltoS: Thanks again for investigating. Sorry for my grep, hoped that limit the log size.
So here is a Pastebin https://pastebin.com/e0XbkcKa from the log.
Please give me a note, if you need something else or more logs.
@enbemokel: The D-Link DCH-Z510 looks (at the rear view) same as my Zipato siren, so it seems to be
the "same" siren, but from other manufacturer. That let me hope, that the hardware is'nt faulty.
All problems started with version 2.3.0. My siren make same problems, after reset the siren, at the beginning
it works for weeks, than it works for days and now it seems that it works only for few days (one or two).
Do you have any experiences with Razberry version lower 2.3.0 (like 2.2.4 or anything?)
Thanks.
Bjoern.
Indeed, at some point it just stops answering. What happens if you just powercycle the device (not Z-Way) - remove and place back the battery? If this will help, the problem is in the device.
Please confirm. We can report that to manufacturer too
enbemokel
Post by enbemokel »
Hi Bjoern, hi PoltoS,
I didn´t remember the version i started with, but i think that it worked in the beginning. Could be a version before 2.3.0.
Sometime I realized that the siren didn´t respond. Btw, I have 4 of these sirens. Configured as Philio PSE02.
I didn´t use batteries inside, but can confirm that it will work after a powercycle. Looks as the siren is going in very deep sleep ;-)
bjoern812
Post by bjoern812 »
Hi PoltoS, hi enbemokel,
same as enbemokel, if I powercycle the device (shutdown/power device) the device starts working again.
But after few days it stops working. Btw, my siren has a battery inside.
But I'm 99% sure, that it worked without problems in Z-Way version lower 2.3.0
Thanks.
Bjoern.
Strange is that the command is actually delivered - the device is reachable. But it do not report back.
BTW, you can stop z-way, move /opt/z-way-server to /opt/z-way-server-latest and /opt/z-way-server-xxxx-xx-xx to /opt/z-way-server and start back (with the old version). I'm pretty sure it will be repeated again, so the problem is not in Z-Way. May be it is just a matter of time, it started to go in this strange state after some time.
