Connecting through FTDI cable instead of USB
intveltr
Post by intveltr »
I've recently starting playing around with the Z-Uno board (Fantastic little device, by the way). However the other day the breadboard with the Z-Uno and a USB cable plugged in fell off my workbench, and wouldn't you know it, the USB connector broke off. Unfortunately it cannot be resoldered...
Is there a way to connect to Z-Uno using an FTDI cable, and if so, which pins do I connect to?
Re: Connecting through FTDI cable instead of USB
No ;( USB is directly connected to pins of the Z-Wave chip USB.
You should try to resolder the port
intveltr
Post by intveltr »
Some of the pads came off with the connector so that's going to be tough.
I'll just order 1 extra to replace it.
A.Harrenberg
Post by A.Harrenberg »
you could still try to upload new sketches with OTA (as described here) and power the device over pin 1 (5 Volt)or over the battery connector / pin 4 (3.3 Volt) directly...
Regards,
Andreas.
Indeed, A.Harrenberg proposed a nice idea! If you don't need USB for daily work, you could do that.
