ProductId
DerLexus
ProductId
Post by DerLexus »
Hi there,
i Play around with a ZUno but have a question. Is it possible to change the product id to make it unique? Background is that the automation Software i use needs a Description file for every device and if i want to use the zuno with 2 different configurations i Need to difference between them.
Thanks for your work!
Edit: changed DeviceId to ProductId
Re: DeviceId
Hello! The device ID is different for all Z-Wave modes in your network. May be you talk about product ID?
DerLexus
Re: DeviceId
Post by DerLexus »
Yes! You are right. I mean product id!
Re: ProductId
It is same ;( we can not change it as it is registered in the Z-Wave Alliance database.
A good controller s/w should base fully on the device interview and not on templates. What is your controller?
DerLexus
Re: ProductId
Post by DerLexus »
It is a Razberry with openHab as software. Im currently checking zway with openhab.
Re: ProductId
Yes, OpenHAB is known for that problem - you need a template for each variant of Z-Uno. Z-Way have no such a problem, but not sure how Z-Way is binded to OpenHAB. Would be nice to get some feedback from you on that topic
OMJ
Re: ProductId
Post by OMJ »
Hi.
What about version number? Can that be parametric and defined in the sketch.
That could make every implementation unique and thereby possible for Openhab to distinguish between different sketches.
Re: ProductId
Version number defines Z-Uno firmware version.
We will certainly make programmable product in future. We are thinking about this
