Hi everyone,
i´m looking for a working example of a simple switch sketch with a physical button/switch.
I managed it to get it working, but the state of the physical button ist not reported to the controller (Fibaro HC2)
Anyone else tried this and have solution?
Switch combined with physical switch
Re: Switch combined with physical switch
There are different solutions. I have used a switch connected to int1. You are probably using a different setup Can you please post the sketch? Either here or as a private message? That will reduce the amount of guesswork from both sides...
This is the demo sketch is used.
I can trigger the LED with the button and from the HC2
But if i use the button, the HC2 didn´t recognize it.
* That is a Simple Sensor Multilevel example
* It measures the value on the potentiometer
* And sends report to the controller if changed
// LED pin number
#define LED_PIN 13
#define switchPin 0
#define Speaker 1
// Last saved LED value
byte currentLEDValue;
int state;
int lastState;
// next macro sets up the Z-Uno channels
// in this example we set up 1 switch binary channel
// you can read more on http://z-uno.z-wave.me/Reference/ZUNO_SWITCH_BINARY/
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(getter, setter));
void setup() {
pinMode(LED_PIN, OUTPUT); // setup pin as output
pinMode(Speaker, OUTPUT); // setup pin as output
void loop() {
state = digitalRead(switchPin);
if (state != lastState)
if (state == HIGH)
if (currentLEDValue == HIGH)
currentLEDValue = LOW;
Serial.println("LED AUS");
else
currentLEDValue = HIGH;
Serial.println("LED EIN");
lastState = state;
digitalWrite(LED_PIN, currentLEDValue);
digitalWrite (Speaker, currentLEDValue);
delay(20);
// function, which sets new relay state
// this function runs only once the controller sends new value
void setter (byte value) {
// value is a variable, holding a "new value"
// which came from the controller or other Z-Wave device
if (value > 0) { // if greater then zero
digitalWrite (LED_PIN, HIGH); //turn LED on
//digitalWrite (Speaker, HIGH); //turn LED on
} else { // if equals zero
digitalWrite(LED_PIN, LOW); //turn LED off
//digitalWrite(Speaker, LOW); //turn LED on
// let's save our value for the situation, when the controller will ask us about it
currentLEDValue = value;
// function, which returns the previously saved relay value
// this function runs only once the controller asks
byte getter (){
return currentLEDValue;
Thanks! Just add zunoSendReport like this and it will work:
http://z-uno.z-wave.me/Reference/zunoSendReport/lastState = state;
zunoSendReport(1);
This works great!
Thanks for the quick help
Have fun with your Z-Uno!
