Generating random packets
justinklchan2
Post by justinklchan2 »
As part of a university research project, I would like to generate random Z-wave packets with the Z-uno board and capture the packets with a software-defined radio.
I do not have any other Z-wave products or peripherals.
Is it possible to generate random Z-wave packets with the Z-uno? If so can anyone point me to an example sketch or outline what commands I would use to do this?
If this is not possible with the Z-uno, is it possible with the UZB? And if so how might I do that.
If it cannot be done with the Z-uno or UZB how might I go about doing this?
Re: Generating random packets
Z-Uno can not generate random packets, but you can use it to report from one of it's 32 packets different pseudo-random values. Not really random, but you can try some f(i) that gives you a wide range of values.
