Aeotec Nano Switch (ZW116) secure inclusion issues
alext
Post by alext »
Got a Aeotec Nano Switch with power consumption reporting (product id ZW116).
When inclusion is performed in non-secure mode (single button press on the device) things work fine except for power consumption reporting.
When inclusion is performed in secure mode (double press on the device's inclusion button) things work fine - interview completes with secure command classes etc. Power consumption is reported, but after a little while the device is no longer reachable and it stops responding to anything sent from the razberry.
A look at Zsniffer shows that the controller sends Nonce requests to the device, but never get's a reply. The device is one hop away and the intermediate node is a Qubino switch.
Anybody seen a similar problem and found a work around (other than just using resetting the device and using non-secure inclusion).
Thanks in advance.
enbemokel
Re: Aeotec Nano Switch (ZW116) secure inclusion issues
Post by enbemokel »
Hi, I had the same symptom with D-Link or compatible siren. After Upgrade to v.3.0.0.RCx the products work.
Even before I was told that the fw of the device was wrong, it worked now with the z-way system. You didn´t write your version......
