Fibaro Door/Window Sensor G5 change alarm state
shrek
Post by shrek »
I would like to ask why I cannot disable Alarm for Fibaro Door/Window Sensor. I tried calling Set(alarmId, value) but with no effect. The state value and its invalidate time does not change.
Here it is how the command class Alarm looks like.
  "name": "Alarm",
  "data": {
    "6": {
      "invalidateTime": 1516291259,
      "updateTime": 1519840622,
      "type": "empty",
      "value": null,
      "typeString": {
        "updateTime": 1516291260,
        "type": "string",
        "value": "Access Control"
      "status": {
        "type": "int",
        "value": 255
      "eventMask": {
        "type": "binary",
        "value": [
          0,
          0,
          192
      "event": {
        "type": "int",
        "value": 23
      "eventString": {
        "type": "string",
        "value": "Window/door is closed"
      "eventParameters": {
        "type": "binary",
        "value": []
      "eventSequence": {
        "invalidateTime": 1519841185,
        "updateTime": 1519841186,
        "type": "empty",
        "value": null
    "7": {
      "invalidateTime": 1516291260,
      "updateTime": 1518689129,
      "type": "empty",
      "value": null,
      "typeString": {
        "updateTime": 1516291261,
        "type": "string",
        "value": "Burglar"
      "status": {
        "type": "int",
        "value": 255
      "eventMask": {
        "type": "binary",
        "value": [
          8
      "event": {
        "type": "int",
        "value": 3
      "eventString": {
        "type": "string",
        "value": "Tampering, product cover removed"
        "type": "binary",
        "value": []
    "invalidateTime": 1516291249,
    "updateTime": 1516291250,
    "type": "empty",
    "value": null,
    "supported": {
      "type": "bool",
      "value": true
    "version": {
      "invalidateTime": 1516291251,
      "updateTime": 1516291252,
      "type": "int",
      "value": 5
    "security": {
      "type": "bool",
      "value": false
    "interviewDone": {
      "type": "bool",
      "value": true
    "interviewCounter": {
      "updateTime": 1516291253,
      "type": "int",
      "value": 9
    "V1supported": {
      "updateTime": 1516291259,
      "type": "bool",
      "value": false
    "typeMask": {
      "type": "binary",
      "value": [
        192
    "V1event": {
      "type": "empty",
      "value": null,
      "alarmType": {
        "type": "empty",
        "value": null
      "level": {
        "type": "empty",
        "value": null
  "id": 113
From what I understand , documentation and command class version, it should be possible to disable/enable alarm. Or am I wrong? Thank you all for your help.
Z-way version is 2.3.6.
Re: Fibaro Door/Window Sensor G5 change alarm state
First are you sure the device accepted the command? It has to wake up to do that.
Second, this feature can be ignored in some devices afaik
shrek
Post by shrek »
Yes it has accepted the command but nothing changes. The same problem is with with fibaro wall plug.
  "name": "Alarm",
  "data": {
    "8": {
      "invalidateTime": 1516285449,
      "updateTime": 1520517386,
      "type": "empty",
      "value": null,
      "typeString": {
        "updateTime": 1516285450,
        "type": "string",
        "value": "Power Management"
      "status": {
        "type": "int",
        "value": 255
      "eventMask": {
        "type": "binary",
        "value": [
          64,
          1
      "event": {
        "type": "int",
        "value": 0
      "eventString": {
        "type": "string",
        "value": null
        "type": "binary",
        "value": []
      "eventSequence": {
        "invalidateTime": 1520517197,
        "updateTime": 1520517198,
        "type": "empty",
        "value": null
    "invalidateTime": 1516285442,
    "updateTime": 1516285443,
    "type": "empty",
    "value": null,
    "supported": {
      "type": "bool",
      "value": true
    "version": {
      "invalidateTime": 1516285444,
      "updateTime": 1516285446,
      "type": "int",
      "value": 5
    "security": {
      "type": "bool",
      "value": false
    "interviewDone": {
      "type": "bool",
      "value": true
      "updateTime": 1516285449,
      "type": "int",
      "value": 9
    "V1supported": {
      "type": "bool",
      "value": false
    "typeMask": {
      "type": "binary",
      "value": [
        0,
        1
    "V1event": {
      "type": "empty",
      "value": null,
      "alarmType": {
        "type": "empty",
        "value": null
      "level": {
        "type": "empty",
        "value": null
  "id": 113
I tried calling
http://192.168.1.21:8083/ZWaveAPI/Run/z ... Set(8,0x0) or
http://192.168.1.21:8083/ZWaveAPI/Run/z ... ].Set(8,0)
but the status is the same. Any idea what I might do wrong? Can I somehow find out from command class definition that Set command will be ignored? Thanks for help.
