Remove original-antenna with ufl connector soldered?
DerLexus
Post by DerLexus »
just a short question. Do i always need to remove the original antenna if i solder a ufl connector and leave it unconnected or can i use the original antenna anyway?
Thx and Bye
Re: Remove original-antenna with ufl connector soldered?
Remove the original. You can remove Pi filter or just unsolder the antenna
