EEPROM write fail in 2.1.3
aleconakad
Post by aleconakad »
I was trying an EEPROM example using latest release 2.1.3. The write was always failing and returning 1. I was using the reference example:
https://z-uno.z-wave.me/Reference/EEPROM/
I tried to fallback to 2.1.1 and still the same problem. It seems something related to the new toolchain 00.08.60 since I did not encounter such an issue with 2.1.1 and toolchain 00.08.50, or it might be that my Z-uno has some HW issues.
I would be glad to try with toolchain 00.08.50 again but I don't know how to revert back to it.
A feedback is appreciated.
NB: my Z-Uno is not connected to any peripherals and is driven entirely by the USB cable connected to my MAC. I didn't try it on Windows yet.
aleconakad
Re: EEPROM write fail in 2.1.3
a slight update: I managed to revert back to 2.1.1 and 00.08.50 toolchain and unfortunately I can still see this problem. I think maybe that my Z-uno is defect.
@PoltoS: Is there any trick I can do to make the EEPROM write operational again? Otherwise the Z-Uno will be sent back to seller.
Regards
If your Z-Uno is remembering it's nodeId/networkId, the EEPROM is ok. We will check the EEPROM API on our side - may be something is broken in the code.
Please try first clean EEPROM in the Arduino IDE menu.
aleconakad
"Please try first clean EEPROM in the Arduino IDE menu." How do you do that? I don't see such an entry in the Arduino IDE menu.
Furthermore, I did not include my Z-Uno in any Z-Wave network yet.
aleconakad
update from my side:
- EEPROM is working correctly.
- Issue is related to the example sketch.
At line 18: instead of
Serial.print(EEPROM.read(i),HEX);
it should be
Serial.print(EEPROM.read(addr + i),HEX);
otherwise it will always print the content of EEPROM at address 0x0000 which is always 0xFF.
- Furthermore, the functions
EEPROM.get(...)
and
EEPROM.put(...)
are not well documented, as they do not return the number of bytes written or read, instead they return always 1 (which I assume is TRUE in case of success).
@PoltoS: could you please check it and give me a feedback to my findings? Thanks
Checked that, indeed the API changed few versions ago to return only Ok (1) and fail (0). Thank you for your report, we have fix the doc and the example accordingly
