Docs state that there should be another thermostat mode: 0x1F (31), that should enable multilevel switch and control valve directly.
The switch is reported during the interview
The problem is that there are no such mode in expert config parameters
and multilevel switch is not visible in the home automation interface, but visible in expert one with 0 to 0 range:
In Spirit's docs there is a reference that we need to also send some basic command class command to enable it
I've seen a lot of docs how to do it on an another controller, but can't achieve it in zway
1. How to send a custom basic class command?
2. How to add another thermostat mode?
Please, give me any clues where to look.
Thank you!
