Zwave.me stick not working
Krflyer
Post by Krflyer »
Hi all,
I have a ZMEEUZB1, which I can't get to work on a Bananapi as well as under Windows. When it didn't pop up in Domoticz, I pulled it from the Banana Pi and inserted in my Windows machine, and downloaded and installed ZWay. The blue light comes on for a second when inserting the device, then goes out. When I check comports in Windows 10, I find it is present as COM2. I changed ports, but does not seem to work.
What I don't understand is when I go to ZWay, network settings, I can't find any setting for the com port. It came up with 9600 baud as default, but I read somewhere it could go much faster.
So questions:
- is the only evidence of the device working the fact that it shows up in Windows device manager as a comport?
- where can I check or set the comport?
- any other ideas?
Re: Zwave.me stick not working
Have you installed the driver?
Which version if Windows?
On win10 it should work out of the box. Do you see the port to vanish when you unplug the dongle?
