App code modification - ClimateControl
Arek
Post by Arek »
Hello
how can I modify installed app code (ClimateControl)? I want to change one value in code but I don't know how to reach it :)
Re: App code modification
Go in /opt/z-way-server/automation/userModules
Arek
Post by Arek »
I did make some changes in Heating app (try to change frost protection from 6 to 8 degree) by modify index.js file (of course I saved an _old version :)) but nothing did change... Do I need to "re-install" app in Z-Wave Smart Home?
edit
ok, I did work in wrong folder (modules). I change Frost Protection to 8 degree, now is working :D
BUT (always there is but)
When I want to extend temp list (adding 27.5 and 28 in 4 places in module.json file) ClimateControl stops working :(
Can someone said what I'm doing wrong?
 "temperature": {
                  "title": "__m_comfort__",
                  "required": false,
                  "enum": [
                    "14",
                    "14.5",
                    "15",
                    "15.5",
                    "16",
                    "16.5",
                    "17",
                    "17.5",
                    "18",
                    "18.5",
                    "19",
                    "19.5",
                    "20",
                    "20.5",
                    "21",
                    "21.5",
                    "22",
                    "22.5",
                    "23",
                    "23.5",
                    "24",
                    "24.5",
                    "25",
                    "25.5",
                    "26",
                    "26.5",
                    "27",
		    "27.5",
                    "28",
                    "F",
                    "E",
                    "C"
Re: App code modification - ClimateControl
You need to edit it in schema and in the labels part
Does your thermostat report min temperature to use it by default instead of 6?
Arek
Post by Arek »
I couldn't find information about reporting min/max available temp. There is only info in technical data that min is 8 and max is 28. When I have clicked Frost Protection nothing was happen and error was registered in event report
You can check in the Thermostat Setpoint CC min and max value
