HowTo Hardware Upgrade (RaZberry to RaZberry2)
cpramhofer
Post by cpramhofer »
Can anyone provide me a detailed Guide how i have to reset the current Controller and include the new one without reincluding all the devices.
I know there is a Feature called „Controller change“ but how does this work when i run razberry on the same RasPi Wehre i have to Change the Hardware (and therefore have to reboot)
micky1500
Re: HowTo Hardware Upgrade (RaZberry to RaZberry2)
Post by micky1500 »
I think "Controller change" is for changing a 'secondary controller' to a 'Primary controller' not for one that is already a 'Primary'
I would start off making both the backups.
1. Smarthome - Management - Backup & Restore
2. Expert - Network - Control - Create Backup
Shutdown cleanly. via telnet/ssh
sudo /etc/init.d/z-way-server stop
sudo shutdown now
power off old Raspberry.
Move Z-wave hardware to new.
Move SD card to new.
That might work
But if you are upgrading to a newer Jessie or Stretch OS
And if you are also upgrading z-way to newer 2.3.8
Probably easiest to build new from the Rasberry OS you have chosen
then install z-way
wget -q -O - http://z-way.z-wave.me/z-way/razberry/latest/install | sudo bash
restore from 'Backup & Restore' page
using the .Zab file
