I am using RaZberry with RPI 3. As a node I am using aeotec's door/windows sensor. I added the sensor to the z-wave>me user interface and I was able to see if the door is on or off. But I want to visualize on or off situation in "thingsboard". Has someone tried something like that?
For any help I will be appreciated.
Thanks.
How can I send datas to thingsboard
Re: How can I send datas to thingsboard
I think you need to look how to make integration HTTP or even make full OAuth integration. We have never used it.
tanimadinmiben
Thanks for your reply @PoltoS . And I am also wondering if I can see the results on my Raspbian's terminal, I mean if the door is open I want to see that on my terminal, how can I handle this?. I don't want to use z-wave>me UI, that's too easy, I just want to play with some codes and I do not know how to...
You can set handler and run terminal programs.
Use Code Device app to make a switch running terminal programs and Bind Devices to bind it with the door sensor.
tanimadinmiben
@PoltoS Yes, that is the main problem, I do not know how to bind the sensor in the code...
Here is another question.
Can I use "The Things Network" to collect data end send it to the "thingsboard" For my z-way?
We do not know The Things Network. Sorry
