Hooked up is an ADA938 OLED display running over I2C as per this example
https://z-uno.z-wave.me/examples/bmp180-oled/
I have edited the address in ZUNO_OLED_I2C.cpp to 0x3D as per this post
https://forum.z-wave.me/viewtopic.php?f ... 23f#p72024
My project works, the display works but its clearly grinding somewhere. Board green LED flashes visibly slower than usual. Code runs for a few hours then Z-Uno hangs. I display a time from start (actually a daily timer) on the OLED, read straight from millis(), and it runs a LOT slower than real time. 10 seconds of time displayed on the OLED takes approx. 16 seconds real world.
I stripped back my code to isolate the cause, and its clearly the OLED part. This simple example is whats left, and makes the board "run slow".
Would really appreciate some advice.
#include "ZUNO_OLED_I2C.h"
OLED oled;
// Pin definitions
#define PIN_OLEDClk 9
#define PIN_OLEDData 10
#define PIN_OLEDReset 11
#define PIN_LED_SOLENOID 13
unsigned long LastBaseUpdateMS = 0;
unsigned long LastDailyUpdateMS = 0;
float WaterTemp = 21.1;
int WaterLevelPct = 50;
float WaterLevelL = 500;
#define WaterLowLevelOn 200
#define WaterLowLevelOff 250
float DailyWaterInRain = 0;
float DailyWaterInFresh = 0;
float DailyWaterOut = 0;
float Meter1TOTAL = 0;
float Meter2TOTAL = 0;
void setup() {
LastDailyUpdateMS = millis();
pinMode(PIN_LED_SOLENOID, OUTPUT);
// Initialise display
pinMode(PIN_OLEDReset, OUTPUT);
digitalWrite(PIN_OLEDReset, HIGH);
delay(1);
digitalWrite(PIN_OLEDReset, LOW);
delay(10);
oled.begin();
oled.clrscr();
void loop() {
LastBaseUpdateMS = millis();
// Calc daily timer
unsigned long ElapsedMS = millis() - LastDailyUpdateMS;
int ElapsedHours = ElapsedMS / 3600000;
int ElapsedMins = (ElapsedMS % 3600000) / 60000;
int ElapsedSecs = ((ElapsedMS % 3600000) % 60000) / 1000;
oled.gotoXY(0, 0);
if (ElapsedHours < 10) {oled.print("0");}
oled.print(ElapsedHours);
oled.print(":");
if (ElapsedMins < 10) {oled.print("0");}
oled.print(ElapsedMins);
oled.print(":");
if (ElapsedSecs < 10) {oled.print("0");}
oled.print(ElapsedSecs);
oled.print(" (");
oled.print(WaterTemp, 1);
oled.println("C) ");
oled.gotoXY(0, 1);
oled.print("Water:");
oled.print(WaterLevelL, 1);
oled.print("L (");
oled.print(WaterLevelPct);
oled.println("%) ");
oled.gotoXY(0, 2);
oled.print("Fill On/Off=");
oled.print(int(WaterLowLevelOn));
oled.print("/");
oled.print(int(WaterLowLevelOff));
oled.println("L");
oled.gotoXY(0, 3);
oled.print("Daily OUT=");
oled.print(DailyWaterOut);
oled.println("L");
oled.gotoXY(0, 4);
oled.print("Daily INfresh=");
oled.print(DailyWaterInFresh);
oled.println("L");
oled.gotoXY(0, 5);
oled.print("Daily INrain=");
oled.print(DailyWaterInRain);
oled.println("L");
oled.gotoXY(0, 6);
oled.print("M1-OUT=");
oled.print(Meter1TOTAL);
oled.println("L");
oled.gotoXY(0, 7);
oled.print("M2-INfresh=");
oled.print(Meter2TOTAL);
oled.println("L");
while(millis() < LastBaseUpdateMS + 1000)
// Wait!
