Can't write NVM data! at=20000
AJTozer
Post by AJTozer »
Uploading firmware to my Z-Uno often fails with the error "Unknown exception "Can't write NVM data! at=20000". Erasing NVM (user, system, or all) generally has no effect. Then, after a while, an upload will work OK. Then it starts failing again.
Any ideas what's going wrong?
Making firmware file: TempSensor.ino-0215.hex ...packihx: read 331 lines, wrote 612: OK.
Fixing ISR table in TempSensor.ino-0215.hex ...
Making binary firmware file TempSensor.ino-0215.bin. Use it in Z-Way for wireless update procedure.[Done]
Elapsed:6.41352915764 s
Sketch uses 9566 bytes (29%) of program storage space. Maximum is 32256 bytes.
Global variables use 187 bytes of dynamic memory.
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
RAW Info:
AA AA BB BB 01 15 01 10
00 01 02 0F 7B 5E B5 79
02 7F C6 62 83 7F FF 7F
FC 01 15 02 0F 4C A3 01
09 19 14 FF FF FF FF FF
FF FF FF FF FF FF FF FF
FF FF FF 0F 11 06 0A 0D
28 01 CB 00 02 1E
FIRMWARE DATA
REVISION:02.15
Z-WAVE FREQUENCY:US
ORIGINAL FW. CRC32: 7B 5E B5 79
MAXIMUM CODE SIZE: 30 KB
CURRENT FW. CRC16: 4C A3
RADIO CHANNELS: 02
HARDWARE DATA
CALIBRATION
MAIN:09 TX: 19 14
DEVICE PUBLIC KEY:
HEX: AF 93 AD D4 D7 4E 60 5D 7E 19 E3 38 4F EC E4 0F 78 10 E6 C4 17 1E AB 4B B6 C1 19 47 FC 07 67 61
DEC: 44947-44500-55118-24669-32281-58168-20460-58383-30736-59076-05918-43851-46785-06471-64519-26465
PRODUCTION DATA
YOUR ZUNO S/N: 0F 11 06 0A 0D 28 01 00 02
PRODUCTION TIME:
WEEK:15 YEAR:2017
WORKSTATION:
NUMBER:1 SEQUENCE:3368
HARDWARE:
CHIP:1546 REVISION:2
Writing NVM data [> ] (0%)(<class '__main__.ProgrammerError'>, 'compiler.py', 610)
Error 0 Unknown exception "Can't write NVM data! at=20000"
Re: Can't write NVM data! at=20000
Program Z-Uno in rescue mode. Looks your sketch is disturbing the dialog with the PC
AJTozer
Post by AJTozer »
Not sure if it matters, but this is Linux.
I've tried using rescue mode a few times. It seems to work a little more reliably, but I still sometimes get that same error. What I've found is that if I just keep retrying the upload it sooner or later works.
I'll keep experimenting with things.
