Hey folks...
Is there a way to push PIN code into Yale doorlock from the Smarthome ?
I know that VERA do that from the UI, being able to send multiple PIN to all or one doorlock at a time! But I can't find that in smarthome...
Yale Doorlock YRD2xx
Re: Yale Doorlock YRD2xx
I tried, but it doesn't work!
I'm unable to put new PIN code for users from the expert mode!
What is the issue? Please be more specific
I'm trying to send new PIN code for users and I also try under UserCode to GET user 1 or 2 for example and got no return.
I tried the UserCode -> ID x , code: 1111 and SET!
All my 7 Deadbolt are having the same issue but I have no problem to put PIN code directly from the touchscreen!
LaverneHouston
having the same issueDesT wrote: ↑13 Mar 2020 04:35I'm trying to send new PIN code for users and I also try under UserCode to GET user 1 or 2 for example and got no return.
All my 7 Deadbolt are having the same issue but I have no problem to put mcdvoice login PIN directly from the touchscreen!
