Issues with the noise meter
temptemp
Post by temptemp »
i only see the channel 2 background noise I never see the channel 1 background noise is this caused by a defect hardware???
Re: Issues with the noise meter
Do you see the graph, but no values? It might be that the values are below sensitivity and in that case it is ok. Also it might be that the noise is saturating the receiver. Please look in logs - every 30 seconds you should see statistics
temptemp
Post by temptemp »
I don't see no values and no statistics for channel 1 only for channel 2.
I only see to low on channel 1 and and on 2 is -94dbm
to low means the noise is really small
temptemp
Post by temptemp »
So that means to low is the best if I trust Google !)
But why is the color red here and not green what it should be???
rafale77
Post by rafale77 »
Maybe my recommendation for future versions @PoltoS, is to set not detectable as -100 or -120 instead of 0 as it is confusing. It is misleading on the graph when we see these square shaped graphs when the points in between are missing because they are too low but are showing as if they did not change from the previous known point.
agree. we will fix it.
rafale77
Post by rafale77 »
Not fixed in 3.0.6 apparently...
Fixed for next version. Thanks for the bug report
