I got several issues with the attached program:
1)
I tried to compile this program with some hall detector, switches and sensors.
When I Added a second sensor "ZON1" I received the Following message:
Custom_sdcpp_.c:428:876:error:use of undeclared identifier 'getterZON1'
To obtain this sensor, I copy and Paste the same one whose name is "ZAG", before no problem, I red and red again the code, and I didn't find my mistake.
2) When I intergrate the Zuno on my Z-Wave network, the channels 1 to 5 are OK, but the channel 6 never came,it is why I would like to add a second one similar to check.
3)I used some interrupt on the program with a hall detector as sensor, I would like to stop and restart the interrupt during some calculation, I didn't find the way on the reference documentation. Is it possible or not?
Thank you by advance for your support
PS: my software is 2.1.5 and my Domotic box is EEDOMUS
Measure the liquid/water flow rate using this code.
Connect Vcc and Gnd of sensor to arduino, and the
signal line to arduino digital pin 2.
programme validé par GB le 26/4/2020 avec coefficient adapté
// pin number, where the two relays are connected
#define RELAY1_PIN 8
#define RELAY2_PIN 7
// zone d'arrosage pin number
// 6 pin - button(ZAG) of Z-Uno board
#define ZAG_PIN 6 //ZAG = Zone d'arrosage general
#define ZON1_PIN 5 //ZAG = Zone d'arrosage general
// 13 pin - user LED of Z-Uno board
#define LED_PIN 13
// channel number
#define ZUNO_CHANNEL_NUMBER_ONE 1
#define ZUNO_CHANNEL_NUMBER_TWO 2
#define ZUNO_CHANNEL_NUMBER_THREE 3
#define ZUNO_CHANNEL_NUMBER_FOUR 4
#define ZUNO_CHANNEL_NUMBER_FIVE 5
#define ZUNO_CHANNEL_NUMBER_SIX 6
#define ZUNO_CHANNEL_NUMBER_SEVEN 7
byte statusLed = 13;
byte sensorPin = 17;
// variable to store current relay state 1
byte lastSetValue1;
// variable to store current relay state 2
byte lastSetValue2;
// variable to store current zone state
byte lastZAGState;
byte lastZON1State;
ZUNO_SETUP_ISR_INT0(onPulse);//Interrupt initialisation
// The hall-effect flow sensor outputs approximately 1.1825 pulses per second per
// litre/minute of flow.
float calibrationFactor = 1.1825;
volatile byte pulseCount;
float flowRate;
unsigned int flowLitres;
unsigned long totalLitres;
unsigned long oldTime;
ZUNO_SETUP_CHANNELS(
//Channel 1
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE, 4, SENSOR_MULTILEVEL_SIZE_FOUR_BYTES, 2, getterVol1),
//Channel 2
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE, 4, SENSOR_MULTILEVEL_SIZE_FOUR_BYTES, 2, getterVol2),
//Channel 3
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE, 4, SENSOR_MULTILEVEL_SIZE_FOUR_BYTES, 2, getterDeb1),
//Channel 4
ZUNO_SWITCH_BINARY(getterRelay1, setterRelay1),
//Channel 5
ZUNO_SWITCH_BINARY(getterRelay2, setterRelay2),
// Channel 6
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterZAG),
// Channel 7
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterZON1)
void setup()
// Initialize a serial connection for reporting values to the host
Serial.begin();
pinMode(LED_PIN, OUTPUT); // set LED pin as output
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pinMode(RELAY1_PIN, OUTPUT);// set up relay pin as output
pinMode(RELAY2_PIN, OUTPUT);// set up relay pin as output
pinMode(ZAG_PIN, INPUT_PULLUP); // set button pin as input
pinMode(ZON1_PIN, INPUT_PULLUP); // set button pin as input
pulseCount = 0;
flowRate = 0.0;
flowLitres = 0;
totalLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 17 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
zunoExtIntMode(ZUNO_EXT_INT0, FALLING);
Main program loop
void loop()
if ((millis() - oldTime) > 1000) // Only process counters once per second
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
// il y a un facteur 100 qui traine donc flowMillilitre sera exprimé en litre
flowLitres = (flowRate / 60) * 100;
// Add the liters passed in this second to the cumulative total
totalLitres += flowLitres;
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
zunoSendReport(1); // send report over the Z-Wave to the controller
zunoSendReport(2); // send report over the Z-Wave to the controller
zunoSendReport(3); // send report over the Z-Wave to the controller
// sample current ZAG state
byte currentZAGState = digitalRead(ZAG_PIN);
if (currentZAGState != lastZAGState) { // if state changes
lastZAGState = currentZAGState; // save new state
zunoSendReport(6); // send report over the Z-Wave to the controller
if (currentZAGState == LOW) { // if button is pressed
digitalWrite(LED_PIN, HIGH); // turn the LED on
} else { // if button is released
digitalWrite(LED_PIN, LOW); // turn the LED off
// sample current ZON1 state
byte currentZON1State = digitalRead(ZON1_PIN);
if (currentZON1State != lastZON1State) { // if state changes
lastZON1State = currentZON1State; // save new state
zunoSendReport(7); // send report over the Z-Wave to the controller
if (currentZON1State == LOW) { // if button is pressed
Insterrupt Service Routine
void onPulse()
// Increment the pulse counter
pulseCount++;
dword getterVol1() {
return flowLitres;
dword getterVol2() {
return totalLitres;
dword getterDeb1() {
return flowRate;
byte getterRelay1() {
return lastSetValue1;
void setterRelay1(byte newValue1) {
// newValue1 is a variable, holding a "value"
// which came from the controller or other Z-Wave device
if (newValue1 > 0) { // if greater then zero
digitalWrite(RELAY1_PIN, HIGH); //turn relay1 on
} else { // if equals zero
digitalWrite(RELAY1_PIN, LOW); //turn relay1 off
// save the new value in a variable
lastSetValue1 = newValue1;
byte getterRelay2() {
return lastSetValue2;
void setterRelay2(byte newValue2) {
// newValue2 is a variable, holding a "value"
if (newValue2 > 0) { // if greater then zero
digitalWrite(RELAY2_PIN, HIGH); //turn relay2 on
digitalWrite(RELAY2_PIN, LOW); //turn relay2 off
lastSetValue2 = newValue2;
byte getterZAG() {
if (lastZAGState == 0) { // si l'arrosge est ON
return 0xff; // return "Triggered" state to the controller
} else { // if arrosage is released
return 0; // return "Idle" state to the controller
byte getterZON1() {
if (lastZON1State == 0) { // si l'arrosge est ON
