Do I need a Z-Way license for UZB if I own Razberry2? Also, does Z-Way run in Docker?
sofakng
Post by sofakng »
I've purchased a Razberry2 and I'm really impressed with Z-Way but it's quite slow on my Raspberry Pi 3.
I could purchase a Raspberry Pi 4, but I also have a big Linux server (16 cores, 32 GB RAM, etc) that I'd like to run Z-Way on instead. I was thinking that I could switch to the UZB USB stick but would I need to purchase a separate license for Z-Way? (could I use my Razberry2 Z-Way license with the UZB stick instead?)
Also, does Z-Way run inside Docker or have a pre-built Docker container?
iblis
Re: Do I need a Z-Way license for UZB if I own Razberry2? Also, does Z-Way run in Docker?
Post by iblis »
You need another license for UZB1. What you could do is convert your Razberry 2 to USB using this: https://www.sparkfun.com/products/12731
sofakng
Post by sofakng »
Interesting idea, thanks.
Any idea why a license is provided with Razberry but not with UZB?
To be able to sell a cheap UZB for third party solutions like Domoticz, Home Assistant, Homeseer...
