Help Mqtt Z-uno
jlm68
Help Mqtt Z-uno
Post by jlm68 »
Recently I have purchased a Z-uno board. In one of my projects I would like to integrate Z-uno with my Mqtt network. I am not sure if I can use some mqtt arduino library or others for allow send-receive Mqtt messages from/to Z-uno. The broker is moskito running on raspberry... Do knows someone if we can work z-uno with Mqtt?
Thank you
Josep
Re: Help Mqtt Z-uno
Use MQTT module that is in onlime modules in Z-Way. If your controller is not Z-Way, then check the controller's support if MQTT
