unwanted script
nathril
unwanted script
Post by nathril »
need some assistance ;)
i used to have a IF THEN script running, polling temp value from sensor and if temp is lower then 40C activate R1 + R2 ELSE turn of R1 + R2, worked like a sharm. But, now i have removed the script but it seems its still running, i have tryed to write a new one with lower temp value, but relay turns on at 40C. now im all lost, i dont know where the script is hiding. anyone have a suggestion?
micky1500
Re: unwanted script
Post by micky1500 »
There are old Apps and new Rules!
For "if-then" you might find you have both running. (delete the one that you don't want)
check:-
Apps - if-then
Automation(Cog) - Rules
nathril
Re: unwanted script
Post by nathril »
iv check both, from what i can tell there is only one script, in Automation - Rules, that script has a IF temp < 37C R1 + R2 ON. under Apps there is nothing
enbemokel
Re: unwanted script
Post by enbemokel »
Try to restart, that helped me with a similiar failure. After restart it was gone.
nathril
Re: unwanted script
Post by nathril »
weee, thank that solved it. overlooked a restart
Dan
Re: unwanted script
Post by Dan »
Oh, God, I had the same issue, but with 5 105db sirens (If away and motion detected than siren on). I took much time and nerves to find the solution and restart raspberry.
Hope, that will be fixed soon
Re: unwanted script
Which one is not unloaded? Under Apps or under Automation?
