How to upgrade UZB stick from 5.19 to 5.39
eliroz
Post by eliroz »
Hi
I have a UZB stick with version 5.19 runs on RPI, I was thinking to manually update it, but the instructions here https://z-wave.me/zmeserialupdater-manual/ aren't clear enough for me.
what is the correct procedure, and should I even risk it? can I brick it?
Is there significant improvements between the versions?
This is my stick info:
          SERIAL INFO
                 VERSION:  05 19  VENDOR:  01 15
          ZME_CAPABILITIES
                  VENDOR:  00 00   NODES: FF
                   FLAGS:  05 00 00 00 00 00 00 00 00 00 00 00 00
          FIRMWARE CRC
                    BOOT:  BB BB      FW:  42 71
          MISC
                    FREQ:  EU
Thanks,
Eli
Re: How to upgrade UZB stick from 5.19 to 5.39
Please use Z-Way to update and enter token "all"
eliroz
Post by eliroz »
Do you mean I need to install zway on the rpi, or there is way to do it with openhabian?
No way to do it from openhub.
eliroz
Post by eliroz »
I see, thanks.
Is there significant improvements between the versions, should I bother with the update?
Well, some cool things about routing - yes. But this is only for large/huge networks. In smaller you don't care.
If you are using Z-Way, you will get many cool features like network analytics and routing map - this is definitelly worth upgrading!
