Zunosenddbg
hperk01
Zunosenddbg
Post by hperk01 »
I have seen reference to this function in the forum and I think it is what I need. I want to send a 4 byte string from my hub to the Z-Uno so I can store it in EEPROM. (The string is a badge ID which is checked when scanning.
I can read the value from EEPROM and check it just fine, I just don't have a way to send a new value remotely.
Is zunosenddbg the right way? If so, how does it get used? There's nothing in the reference documentation
Re: Zunosenddbg
zunoSendDbg is to send from Z-Uno to the hub (and it is a debug tool). But not the wise versa. I suggest to use configuratuon parameters in your case as it suits much better your task.
aleconakad
Re: Zunosenddbg
Post by aleconakad »
can I use zunoSendDbg as well to send data to associated nodes?
Re: Zunosenddbg
Yes, but this is hardcore ;) I would suggest to use the standard commands
aleconakad
Re: Zunosenddbg
I would really appreciate if you can point me out to the right direction on how to use it. Let me worry about the Hardcore stuff :D
Re: Zunosenddbg
