GPIO output device
nanobit123
GPIO output device
Post by nanobit123 »
Dear sirs,
I have searched this forum for days and could not find a solution, and I am sure somebody also dealed with this situation:
I need to switch on and off a RaspberryPI GPIO output as it would be a Z-wave switch element added to a home.
Please advice a link or a solution
Thanks in advance
Re: GPIO output device
If you want to have the switch in the Z-Way UI, use Code Device app and call from it some python script that will do the job (look in Raspberry Pi documentation).
If you want to have a Z-Wave switch doing GPIO, check Z-Uno project
